Question about GE 28112EE2 Cordless Phone
Caller Id A lot of the calls don't show any information for caller id. My old analog showed almost all calls.
  • mikecmch Feb 01, 2008
    I spent two hours on the phone with tech support. Got mad and
    took the phone back.
  • Anonymous Feb 05, 2008
    I have the same problem. This phone sucks
I have the same problem and found that replacing the cord did not work.I also have another phone connected to the line and it shows all caller id while this one does not This phone sucks but unfortunately I threw the receipt away. Now I cant get my money back.
Posted on Feb 05, 2008
  • 4 Answers
Try changing the cord between the base unit and the phone jack. Some phones are pretty fussy about this, and when they are, it's usually the caller ID information that gets clobbered. Alternatively, try attaching the base unit to a different phone jack - preferably the jack with the shortest wiring run to where the phone service comes into your home.
Posted on Feb 01, 2008
Caller id will not show on the display.
Did you change carriers? A lot of the VoIP carriers like vonage and magic jack will only give you the telephone number on caller id, but not the name.
I have magic jack now and they call that "caller id", but having moved from a carrier that had name attachment i assumed all caller id's had name and phone number both...but not so
Mar 09, 2015 | Panasonic KX-T7453 Corded Phone
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Incoming call does not show in caller id window all the time. sometimes it simply says "incoming call" without identifying the caller. other times is works proberly.
Caller ID information is sent after the first full ring. If the call is answered too soon, the caller ID information may not have been sent yet. Some of the many and varied networks do not send caller ID information. In this case you may notice that caller ID is missing only on calls from certain callers. Occasionally bad data is sent, causing your phone to reject it.
Jan 23, 2011 | Panasonic KX-TG5632 Phone
I just received KX-T7730 phone with an LCD screen and it is not showing the caller ID # that is dialing in. It only displays CO 1. The previous phone similar to KX-T7730 shows the caller id #. So how can I...
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
I have a callpilot 100/150 we acquired an add-on
First thing, the Call Pilot is your voicemail, not your telephone system. Your telephone system is most likely a Norstar CICs unit.
If the lines(trunks) are analog, it is the local telco provider that is handing out your caller ID.
Outgoing caller ID is not one of the features of the system for analog circuits. If you were running a PRI or BRI, then the system can hand out the caller ID. I would ask your telco provider to check the outgoing caller ID once again.
Jun 10, 2009 | NorStar CallPilot 100
Caller id not working, called tele ph comp they said to change batt, have base unit with one in other room, base one and two not showing caller id, the batt are showing full.
Caller ID information is passed between the first and second rings.
Try connecting a regular corded telephone or a standalone Caller ID box. Does Caller ID information show up?
If you have multiple telephones (I don't mean a single cordless telephone base with multiple handsets) and none of them are showing Caller ID after 3 rings it would appear that the telephone company does not have Caller ID turned on for your telephone line.
Oct 29, 2008 | Lands Phones
Caller id
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
Feb 01, 2008 | Uniden TRU9480 Cordless Telephone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
No caller ID information for GE Caller ID phone ( Model # 29385GE1)
I must have gotten your unit. Mine did work ONCE after it had been installed for about a week. But it never worked again and we pitched it. Buy something else.
Oct 21, 2007 | GE 29385GE1 Corded Phone
GE 28112EE2 Cordless Phone Logo
101 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
