Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
FrigidAire Side By Side Slow IceMaker
The icemaker stopped making ice. I changed the 2 valuves out and now I am making ice again. Does anyone know how to speed the cycle time up. It makes ice about once every 2.5 hours. It only takes about 30 minues for the water to freeze. The slow cycle time has existed before I had the no ice problem.
  • KrissHart Mar 04, 2008
    Thanks for the reply. I turned the temp down and I am producing a bunch of ice again. I should have tried that before posting, but I am just happy to have ice.
  • Anonymous Mar 12, 2008
    Kriss I am having the same problem, did you say you just replaced the water valve?, did you test the valve to know that was the problem?
    Thanks
    President:
  • Frigidaire Master
  • 2,651 Answers
There is no way to speed up the ice production, factory set only way to produse mor os depending on age of refig might have an "extra ice" button on display. even thats atemporary fix and probly speed up by 20--30 min
Posted on Mar 04, 2008
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
Replaced water filter on my Frigedaire refrigerator and it is leaking where the filter is it is making ice when the bar is raised for no more ice it does not lead but when the bar is down to make ice is...
The problem there is going to be one of 2 related causes.
The tube in the back of the icemaker where the water enters it is partially frozen and when the water comes into the icemaker some of it is spraying into the bin instead of filling into the icemaker.Remove the icemaker and check and thaw that tube.
That tube is out of place so once again instead of water filling into icemaker correctly some of it is running into ice bucket instead of icemaker.
Gene
Aug 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
The freezer side every 2 to 3 days the fan makes a noise and the ice begins to melt. It drips from the ice dispenser. The following day every thing is frozen again. The refrigerator stays cold.
This may sound a bit harsh but turn off the water to your icemaker for several days. What your describing sounds like the icemaker water valve is leaking water by the diaphram and is leaking into your freezer. This is a common symptom of failing ice maker water valves. I just went through this on my own personal refrigerator where ice was building up. After changing the icemaker water valve all the ice build up ceased.
So turn off the icemaker water supply for a few days.. break out the ice trays if need be and see if the ice build up stops. If it does then the ice maker water valve will need to be replaced. Fyi they run $38 to 55.00 on average and you can change it yourself. Should the need arise here is a link to a replacement water valve source: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=113933&diagram_id=337176#d337176
Close up view: http://www.appliancepartspros.com/part_details.aspx?part_id=4298908
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Frigidaire FRS26R4A Side by Side...
My ice maker has'nt made ice the whole day
The arm on the icemaker can NOT be blocked. If anything is in the way it will stop and time out the icemaker. The face of teh icemaker is a timer, that arm lets the timer know it is ok to cycle through. Remove obstacles and then lift arm up and down to reset it. It's a thin silver bar on side of the ice maker.
Jul 07, 2010 | Frigidaire FRS3R5EMB Side by Side...
My icemaker works slow to make ice. Sears Kenmore side by side refrigerator. Model.57572791
check temperature in freezer compartment,needs to be near zero,if it is,there may be a problem with the internal thermostat on the icemaker,also checkthat the icemaker mold is filling completely with water,all the cavities should fill
Jan 22, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS26ZRGW8 ice maker stopped working
on your icemaker you can tell if its a internal problem or a water valve ,,,,, 1st feel inside for any ice ,,, if ice is in icemaker the valve is working ,,, pull fingers on icemaker to get it started and watch it, if it makes its cycle and fills again the the icemaker itself is bad ,,, contact me and i will see if i can help with part or parts / larry
Dec 08, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire Side by Side Icemaker
The icemaker evaporator system that releases the cubes is faulty , and must be replaced.
Apr 02, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
747 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
