Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Hoover Agility steam cleaner
I have had my Agility for a few years had have not had an issue till now. When I went to use the hose attachment the water sprayed out of the attachement and sucked up fine but, I noticed at the same time I used the attachment water was pouring out the bottome of the machine. I went through a tank of water in no time-plus had to suck up all the water that had soaked the floor under the machine body. Any idea what could be causing the leakage in the base?
Thanks
Mary
  • Anonymous Mar 20, 2014
    Water and, once heated, steam leaks from bottom of jet steamer. Poor steam pressure when hoses are attached
    President:
  • 1,673 Answers
Sounds like you have a broken water line, or it just came off. You would have to remove the top housing to get to the water lines. Or at the bottom of where the solution tank sits on, is the reservior asm. there are lines going there also. Bottom of the tank, the valve is stuck open. The trigger on the handle is stuck pushing down on the reservior asm.
Posted on Jan 29, 2008
I need the schematic diagram for a Hoover Agility F6215-900 steam vac in order to replace the lower recovery duct hose
You will find this URL of help:
http://www.ereplacementparts.com/search_result.php
Please provide a Thumbs Up if you find this solution helpful.
Paul
Oct 04, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
Hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Jan 24, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Lower hose broken hoover agility how to replace
to replace a hose on the Hoover V2 is a pain in the you know what. i would recommend
1. take it in and have a professional repair shop do it.
2. trade the V2 in for the Hoover PowerMax steam cleaner with spinscrub they are 100X better then the V2's and about 1/2 the price
Jul 28, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
How to attach the upholstry cleaners
Easliy download the manual at Hoover.com.
The hose attached in the front of the unit on the clear front panel. Lift up the center cap and attached the hose. Then attache the supply hose to the side of steam vac for your solution.
May 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My hoover carpet cleaner's brushes dont roll, it is a steam vav power max
They may not be "stapped" in postion correctly. Do you have the manual?
If not go to: www.hoover.com for a free copy.
Mar 15, 2009 | Hoover F6213-900 SteamVac Agility...
There is no steam on my hoover steam vac
They do not really "steam." They use hot water to clean your carpets with a mix of cleaner as well. You will not see your unit actually steam.
Dec 09, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose to stress. It certainly cannot last for many full bends of the handle.
We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
UPDATE: I McGuyverized it myself with a dremel cutoff tool, some vinyl tubing, some 2-part epoxy, and a lot of faith. It sure isn't pretty, but it sucks again. :)
May 30, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
107 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
