Question about Maytag MAH6700AWW Neptune Front-Load Washer
Washing machine it shuts down water filling cycle
Everytime when I start the washing machine it shuts down water filling cycle within few seconds. Is something clogged? water filter(s)? here are they?
Washer will not compete fill cycle without repeated pressing of start. Machine will pump out but will not agitate or spin
  • Anonymous Mar 17, 2014
    machine just keeps repeating the cleaning cycle without stoping
    Genius:
  • 1,554 Answers
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Posted on Jan 29, 2008
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
GE washer wont drain or spin, lid switch has been replaced and so has the timer. At the start of cycle it fills and aggitates properly.
If the machine tries to spin for a few seconds and shuts down because the tub is full of water, then - The first thing I would do is check the pump. You may have something blocking the pump or the pump could have failed. Newer models built within the last 10 - 15 years must drain their water down first before they are able to spin.
Jul 28, 2010 | GE Washing Machines
Kenmore 110 washing machine thermally cycles
Does it operate properly if you or something holds the switch down? If yes, then extend the end of the lid switch with hot glue, epoxy, or silicon glue to allow the switch to be pressed sown further. You can also build up the contact area under the lid if you choose--same result.
Aug 07, 2009 | Washing Machines
Maytag neptune,shuts down within 10 seconds after start button is pushed
If it has worked for a year and your able to choose different cycles with the same result. It seems to functions with one common element failing. If the control unit cant detect how full the machine is with water it will shut down. Sounds like a water problem steming from your pressure switch. Not sure which model you have but usually it will sit on the water pump or under the console with a clear hose if under the console. If so a quick test of attaching an ohm meter set on continuity then blowing lightly to see if under pressure the switch reacts by closing if it doesnt then the switch is bad.
Sep 16, 2008 | Washing Machines
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah3000aww
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Jan 19, 2008 | Maytag Neptune Washer
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
199 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
