Question about InFocus X1 Multimedia Projector
INFOCUS Lamp replacement
Just replaced lamp and unable to reset lamp clock. Followed instructions in manual and it still wont reset. The projector sounds like it is trying to "boot" up but it just shuts down after about 30 secs giving me the blinking red lights again.
  • Anonymous Apr 03, 2008
    I have the same problem. Have tried holding down both volume keys on power up but it does not help. I did replace the lamp about 100 hrs ago but did not reset the lamp timer.
    Actually second timne around holding down the volume keys on power up seems to have worked!! Thanks.
    Problem Solver:
  • 17 Answers
You tried holding down both of the volume keys for 10 seconds while powering up?
Posted on Feb 19, 2008
  • 26 Answers
If the counter had expired, the projector would not even attempt a power up. You have other issues. How many blinks on the light?
Posted on Feb 28, 2008
  • sheridan1952 Apr 04, 2008
    The technique of holding down the Volume buttons for 10 seconds while
    switching is really intended for use when the lamp counter has expired
    and the projector won't power up.
    If the lamp is replaced in the normal course of operation and the
    projector comes on, then the lamp counter can be reset in the menu.
6ya staff
SOURCE:
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
chances are its the projector itself that you are having an issue with, one more thing that you can do is for you to clean the filters, try cleaning the filters and try reinstalling the lamp, then power it back on, if you are getting the same thing still, have the projector service or if within warranty have it replaced. best i got. Thanks for using Fixya!
Jul 01, 2008 | InFocus X1 Multimedia Projector
Warning message for lamp replacement appears at each power up!
After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
The old lamp in my in focus LS 110 reached its maximum hours. I replaced with a new lamp but it is not firing up - i think I need to reset the lamp hours but don't know how and don't have the...
Sorry, I am not familiar with the Infocus LS 110 but the user guide can be downloaded at
http://www.retrevo.com/support/InFocus-LS110-Projectors-manual/id/1081dj697/t/2/
You don't need to put in your email address but you will need to type in the numbers. It come in a PDF format so you will need adobie acrobat to read the file. It should have instructions on how to reset the lamp hours.
Hope this helps
Aug 01, 2011 | InFocus LS 110 Multimedia Projector
I have replaced the lamp and followed the reset lamp instructions, but it won't reset the lamp - still shows to change the lamp. I've tried it several times.
Make sure you are punching the right buttons on the circle of buttons. There are inside buttons and outside buttons.
It took me several tries until I realized I was pushing the outside ones instead of the inside ones. Once I carefully looked at the button setup, I had no problems.
Apr 01, 2011 | Sharp DT-400 Multimedia Projector
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Light comes on and goes off.
the lamp may have exceeded 2000 hours. you need to replace the lamp and reset the lamphours. you can check in the menu.
Aug 08, 2009 | InFocus Projector Lamp for IN24+, IN26+
InFocus X1 Multimedia Projector Logo
815 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
