ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard Logo
Posted on Jan 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sata Config How do i get my motherboard setup to recognize my SATA hard drive
  • JacquesP Jan 30, 2008
    after the bios setup, it comes up with nvidia raid and you set the rid up there by pressing f10. It shows healthy but still does not show in the bios?
Anonymous
Level 2:
  • Expert 145 Answers
  • Posted on Jan 29, 2008
Anonymous
Expert
Level 2:
Answers
145
Questions
Helped
72861
Points
318
Go to bios settings, usually F2 on boot, then CMOS setup, check that it is there, and if not try to have the bios search/recognize it. Save settings and reboot.
  • Anonymous Jan 31, 2008
    Do you have your SATA cable attached to the first SATA port on your motherboard, or do you have multiple SATA devices?
Bios setup does not show sata HD windos xp find them
I have had problems like this many times with some of my IBM machines. What i find most often the reason the bios will not recognize them is because the hard drive has gone bad.
Troubleshooting 1. Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from motherboard and hard drive. Unplug power cable from hard drive.
Plug the sata cable back into the motherboard and into the hard drive. Plug the power cable back into the hard drive. Plug the power cable back into the computer.
Boot computer and enter bios(by pressing F8, Enter, Del ect..) Does the hard drive show in there now?
2. If you have another hard drive.
Unplug power cable from computer before doing anything inside of the computer. Unplug sata cable from hard drive. Unplug power cable from hard drive.
Plug the sata cable into the second hard drive. Plug the power cable into the second hard drive. Plug the power cable back into the computer.
Boot up the computer and enter the bios. Does this hard drive show in the bios? If so then i would say that your original hard drive has gone bad.
3answers
I need some help...A friends laptop is very messed up, i need to install his SATA Hard drive on my computer. I have a SATA Hookup on it, its all hooked up, but WindowsXP is not recognizing it. My brother...
Hi
Thank you for your query
From what you are describing you are missing the SATA controller
Please do the following
1) Go to www.devicedoctor.com and download and install application
2) Once installed load up and click on begin scan
3) Once it has scanned it will probably pick up missing SATA controller and give you the option to download
4) Download the SATA controller and install
5) Reboot PC and the SATA drive should be recognised
2answers
Motherboard for GX280 fails to recognize Hard drives.
try to disconnect one drive and check it if you have 2 hard disks
SATA 2 HDD
I think, one possible way is to manually force sata 2 (there is no such thing as sata 2) to sata 1 by using a jumper for the hard drive. For exact details, please consult the sticker on the hdd or contact the hdd manufacturer for firmware updates. And please report back, especially if it's a success. (Damn, the VT8237)
2answers
Sata drive not recognized at boot up
I HAVE UPLOADED THE MANUAL HERE, IF YOU DON'T WANT TO WAIT THEN GET INTO YOUR BIOS BY DOING A HARD BOOT AND HITTING THE DELETE BUTTON ON START-UP.IF THE MOTHERBOARD SUPPORTS SATA , TO WHICH I FOUND NO CONFIRMATION , YOU CAN CHANGE IT BY GOING INTO THE ADVANCED SETUP PAGE AND CHANGE THE FIRST BOOT DEVICE TO SATA RATHER THAN IDE. YOU WILL ALSO WANT TO CHECK THE PCI SETTINGS AS WELL FOR YOUR CONTRLOLLER CARD ....GOOD LUCK
9helpful
3answers
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to...
you will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Secondary hard drive
I had this trouble had to reset BIOS to default then it worked but would either recognize IDE drive and not SATA remove IDE SATA was recognized
Its something in the BIOS setup As I do not know your BIOS you will have to check it out with *********** board manual how to do it to setup both drives
3answers
PC Help
Find the SATA Driver for the Hard Drive. It has to be installed first.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
