It most likely needs shock absorbers replaced. You can go online for your make and model washer. To see how to replace them . It is an easy job and the parts are not very expensive.you can find the parts online also.
Every washing machine has crew type legs on each corner, if it teaters from corner to corner it is not properly leveled. you need to adjust the legs up and down until the machine is level and does not teater from corner to corner, like rock solid..when you put in a load of lawndry that is lop sided, the machine has a tendency to dance around the floor during the spin cycle, to stop this open the lid and re-adjust the lawndry evenly then close the lid and it should quit dancing around the floor.
Now if your floor is too weak, you need to get under the house and put in somemore beams to support the weight of the machine....
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
Cars, does the basket lean to one side? There might be a couple of issues. The coupler that seats between the motor and trans could be wollowed out causing vibration. Another is that one of the balance springs came off or broke. I'm going to attach a photo of the springs so you can see what this looks like. You can remove the whole cabinet to check things out or tip the washer back and take a look.
