Question about Minolta QMS PagePro 9100 Laser Printer
Monolta 9100 error code 18 won't reset or clear
Replaced fuser and error code 18 appeared unable to clear unit of code-printer is stuck.
  • vaironp1 Feb 03, 2009
    smae code... i have cleaned all the parts around the fuser.
Download image to parallel port
Posted on Jul 22, 2008
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
How do I reset fatal error code 980 on C 610
check the fuser unit for paper/media stuck to the orange fuser roller. power off machine and re-install. If that dont work fuser unit must be replaced
May 18, 2014 | OKI C5650n LED Laser Printer
Fatal error 923, 922
-922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
If this is the first time you have seen the error, turn the printer off and on.
-Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
- 923 Fuser Error indicates that the fuser unit is getting too hot while printing or when the printer is idle. Make sure that nothing is stuck inside the fuser unit that can cause the fuser unit to overheat. To check for any stuck sheets of paper in the fuser unit:
Locate the rear door and open it. The rear door opens and drops down towards you.
Look into the back of the printer. See if there is any paper or any other item stuck there that could be causing the fuser unit to overheat.
If you cannot find anything jammed up or broken in the back of the printer, open the upper front cover of the printer and remove the toner cartridge. Look into the printer from the front. See if you can see anything jammed into the back area of the printer.
If nothing appears to be jammed in the printer, the fuser unit or the main power supply of the printer will probably need to be replaced to fix this problem.
Mar 14, 2011 | Xante Ilumina Digital Color Press Printer
I have a Konica Minolta bizhub D2510F it gives me this error C0501. after searching around I found out that this error is a Fuser error. I replaced the Fuser and the PhotoConductor but I still get the same...
The error has to be manually reset. Here is what I found from the official procedure. Hope it works. How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521). Solution To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
Note: It is not in the same location as the models 7915/7920.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Feb 03, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Replace fusing unit error
Can you put the old fuser back, just to see if the message clears.
Mar 04, 2010 | Ricoh Aficio AP3800C Laser Printer
Error code c0520 konica minolta c350
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution To clear the fuser error code, perform the following after correcting the cause:
Jan 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
Error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
Dec 02, 2009 | Sharp AR-507 Copier
Aficio sp4100n sc541 error
Press total clear press 1 0 7 and press for more off 3 second the clear stop key to enter to service program mode.
Then enter SP 5-810 (SC code reset),
select execute, select close. Exit
SP mode, turn the main power
switch off then on.
Aug 05, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Turn on get error c0500 on a minolta ep4050
the error codes means Low fuser temperature during warm-up
Jul 06, 2009 | Office Equipment & Supplies
Minolta QMS PagePro 9100 Laser Printer Logo
288 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
