Question about Logitech Inc MX610 Laser Cordless Mouse DH931350
Mouse doesn't turn on
Hello
when i put in the battery the green light turn on but two seconds later it goes off and mouse doesn't work is there any solution ar i have to go with that to service
  • daxoss Jan 29, 2008
    Daxoss\
    mouse still not work this is not a problem with the transmiter i think there is something wrong with the mouse it doesn't wont to turn on
    if you hav e another solution please let me know
  • nickeym1 Dec 29, 2008
    hi i can get it to turn on by using the method described holding left button and pressing right five times the lights come on on the top of mouse and everything but there does not seem to be a laser light on the bottom i have downloaded latest drivers and software and still does not work. when i look under the mouse where the laser light is if i look very close i can see a tiny red dot of light any help would be greatly appreciated thanks.
I have a model like that and the light goes out but it does work, except for the actual X-Y mouse control (all 10 buttons....) It seems as though you should try the latest drivers and connection utility, do the connect bit where you HOLD the left button (on the right handed model...,) hit power on the mouse, click the right button 5 times, and the utility associates that mouse with your particular receiver.
If it doesn't work after that, and your batteries are OK, then you get to shop for another one too.
Posted on Jun 11, 2008
    Champion:
  • 217 Answers
This wireless mouse should have a transmitter that is plugged into the computer. Try replugging that in, and if there is a connect button on it, try pressing that as well.
Posted on Jan 29, 2008
  • Anonymous Jan 29, 2008
    I don't know why my solution was rated inappropriate. It was a logical response, given the amount of information provided.
    If the mouse is still not working, then you'll need to buy a new one.
6ya staff
SOURCE:
Have a Wireless logitech mouse. Replaced battery. Green light comes on, but then goes off. What next?
From Logitech's website, "This is normal behavior of the mouse.
The green battery light of your ]logitech] mouse will come on for a few seconds to indicate the battery condition and then go out. This will occur when you power on your mouse and when you replace the batteries. The battery light goes out after a few seconds to conserve battery power."
Nov 27, 2017 | Logitech Computers & Internet
Green light comes on for 20 seconds then goes off and mouse doesn't work Microsoft Arc Mouse 1349
Try switching ports and try using it on another computer and check if it works or not. If not then replace it
Jul 27, 2011 | Microsoft ARC Mouse
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
My mouse isn't working
Try to put new batteries.
Apr 30, 2017 | Logitech 931150 Mouse
My mouse isnt responding at all. the weird thing is, when i put the battery in, the light doesnt turn on
you need to press the reset switch ont he recever that connect to the computer and then the mouse so it can sink up.
Dec 04, 2009 | Logitech V220 Mouse
Optical light on Mouse not working
maybe the battery?
follow the steps below to troubleshoot the mouse
Wireless mouse does not respond (generic instructions)
Try to Resynchronize your device with the receiver(connector)
Follow these steps.:
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse at least 6 feet away.
1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
2. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
3. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 3 again.
For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
or
Try different port and restart your computer.
or
Reinsert the batteries or install fresh batteries
If you have the possibility check whether the problem is because of your computer or the device, try the mouse or the keyboard on a different computer.
Sep 06, 2009 | Microsoft Wireless Notebook Optical Mouse...
Logitech mouse won't work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Dec 05, 2008 | Computers & Internet
Cordless Mouse Just quit working While In Use
Most cordless mouse I saw has a reset button. Press this button, make sure you're in the transmission distance from the receiver when you do this.
Sep 12, 2008 | Logitech Cordless Mouse
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Jul 21, 2008 | Logitech MX 600 097855036162
Open Questions:
See all Logitech Inc MX610 Laser Cordless Mouse DH931350 Questions
Computers & Internet Logo
135 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Alun Cox
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
