I can't get the handset to connect with the base. I tried to re-register the handset and it still will not connect - I get an "error" message. Now it the handset just asks "please register this handset" when I turn it on. How do I get it to connect to the base?
I finally found the answer on the sony site. The critical step that was missing from the directions that came with the phone was number 6. Once you reset the base to "test" the handset links immediately. Use the link below to get the instructions.
http://www.iq.sony.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=CISCV3,Company={46BFA530-E01F-4F7C-B98B-69C2AA06051B},Case=Obj(158061),TS=externalv4,T=case.tem,VARSET_MODELNUM=,VARSET_OBJ=158061,VARSET_TOP=TRUE,workstage=all,question=ref(QC):ord(1),question=ref(QB):ord(1)
My new phone finally DID register when I followed the procedure WITH THE 2ND (ORIGINAL) HANDSET NEAR THE BASE.
SORRY TO BE REDUNDANT BUT DID YOU HAVE PHONE IN STAND BY AND NEAR BASE.
THEN PRESS PGM
THEN INTERCOM
THE SCREEN SHOULD SAY ENTER SYSTEM ID
ENTER THE 10 DIGITS SYSTEM ID ( THIS NUMBER IS ON A STICKER ON THE BOTTOM OF THE BASE PHONE)
THEN PRESS PGM.
MAKE SURE YOU ARE PUTTING THE CORRECT ID NUMBER IN THE PHONE
I HOPE THIS HELPS
Thanks for getting back to me. I had the phone in my hand, next to the base, when I did what you instructed (3 or 4 times). It just keeps asking me to register. Prior to my trying to re-register the phone, it just would not connect to the base. Any other suggestions?
I have the Sony A2780 with a new SPP-H273. The handset will not register.
Phone is charged - near the base - have the correct ID.
PGM - INTERCOM - i.d. number - PGM
5 beeps and "ERROR"
Called the 800/222-7669 Sony direct response # - they wanted $14.95 to fix it or not fix it - same price.
I said forget it.
http://www.iq.sony.com/SRVS/CGI-BIN/WEBC...{46BFA530-E01F-4F7C-B98B-69C2AA06051B},Case=Obj(158061),TS=externalv4,T=case.tem,VARSET_MODELNUM=,VARSET_OBJ=158061,VARSET_TOP=TRUE,workstage=all,question=ref(QC):ord(1),question=ref(QB):ord(1)
Comment by harvey36, posted on Feb 18, 2008
I can't get the handset to connect with the base. I had to get a new battery pack, it arrived and I installed it and charged the phone for two days but It will not connect - I get a message that says Connecting, then about five seconds later the message says"No Connection". I have a lot invested in the new battery pack, but I can't make the cordless handset phone work.
HELP!
Have the same problem. When I click on your link for instructions on how to register headset with system it takes me to a link which is no longer available.What is step six which was left out of manual ? Must the headset be in the charging stand. I have followed all the steps and still get 5 Beeps and error message. Then the headset tells me you must register phone.
[email protected]
Thank You
No connection of handset with base set
handset can not connect with base station
