Question about Philips 32PW6006 32" TV
PHILIPS PW8751/12 THE RED LED FLASHES AND TV NOT STARTUP
  • Anonymous Jul 27, 2008
    red standby libght flashes constantly have to turn on off at least 30 times for it to come on
  • 149 Answers
Hi there, red light flashes means a shorted electronics componets is needed to be replaced. check for horizontal section prob. it maybe a flyback transformer, a transistor or diode. do some test. ty
Posted on Jan 29, 2008
My Plasma 42FD9954 42 TV doesnt work
Familiar problem on Philips Plasma units. PSU or Sustain board failing.
Jan 16, 2013 | Philips 42FD9954 42 in. Plasma HDTV
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
I have a 50" Philips
Most likely the power supply capacitors are going bad.
Opening the TV and replacing any swollen caps may solve your issue.
Thanks
Roety
Aug 16, 2011 | Philips Televison & Video
Plasma tv in protect mode
One of the PCB's inside has an incorrect voltage/short or dry joint, all TV now days have a diagnostic startup mode which checks all the boards, one of yours threw up a problem so the TV put itself into Protect Mode so that it doesn't do anymore damage.
Get it checked out by an engineer.
Thanks
Oct 01, 2009 | Televison & Video
My philips 50p8341 beeps then flashes the red led 4 times
4 Blinks means that an incorrect voltage had been detected on the +5V circuit coming from PSU to digital control board.
The PSU must be tested and eventually repaired or replaced.
Aug 08, 2009 | Philips Televison & Video
I have the Philips 27PT6441/37 TV that turns on to the point of hearing sound then instantly turns off and flashes the led 3,2,1.
Plus horizontal lines on top of the screen
Jul 08, 2009 | Philips 27PT6441 27" TV
RCA 32WR22E startup problem(red LED blink code)
This model (RCA 32WR22E) has a child lock in which the LED flashes 2 then 7. Page GB6 in the user manual :To unlock press any numerical key on the remote control and the TV should start.
Feb 20, 2009 | Televison & Video
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 20, 2009 | Televison & Video
Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Dec 06, 2008 | Televison & Video
Philips 32PW6006 32" TV Logo
260 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
