Question about HP f2105 21" LCD Monitor
DVI connection not working
The DVI hookup doesn't display properly, I have to use the standard monitor hookup to see it. When I hookup my monitor using the DVI my screen comes up completely distorted and all yellow. I can't see anything but Id like to use the DVI if it can work. My graphics card is NVIDIA GeForce 6600 GT SLi. I'd like to keep the SLi enabled instead of running on just 1 card.
Monitor is HP f2105
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
I have a Hitachi 55hdt51M 55" plasma monitor/TV with no AVC75 controller. Can I operate this monitor/TV without a controller box vias some sort of direct hookup? The only input connection is labeled "in...
You can use either input to use the monitor as long as you have the correct cable. HD15 to DVI can be converted and so can HDMI to DVI. Only hold up is the type of DVI. There are three types and I cannot remember for sure the designation but I believe there is an I, S and a D. The device will have to be able to display in a matching format.
Jan 27, 2014 | Televison & Video
Hi, I have a asus VW192DR lcd monitor but it cannot open properly, only mixed colors, is there any chance that i can fix it on my own? pls help.
ASUS DISPLAYS are pretty FUZZY, HARD TO REPAIR but also HD and VIVID. ASUS DISPLAYS are usually HARD SEALED from the inside. Try paying it a rest and RESTARTING . Doesn't work? , DETACH the STAND to make it easy to work. The SCREWS to OPEN an LCD MONITOR are usually near the VGA/DVI/HDMI CONNECTORS. HOPE THIS HELPS.
Sep 08, 2012 | ASUS LCD Monitor
How to install software to gfive g111 mobile
Computer Monitors
Nintendo home consoles are designed for use through home televisions and VCRs, using standard A/V, S-Video, component, or RF connectors (for older systems). Computer monitors typically do not have these connections. There are however two ways a hookup to a computer monitor could be accomplished:
With a PC TV Card:
A TV card inserted into your PC may allow you to connect your system if the card has the proper connections (such as RF, A/V, S-Video, component, or Coaxial). However, we have found that the image quality is not as clear as it is on a TV, in most cases.
With a Direct Connection (RGB or DVI Cables):
Nintendo does not manufacture any cables to make an RGB or DVI connection. While other companies may manufacture wires that can make this possible, we are not able to recommend them, as they are not licensed by Nintendo.
May 19, 2012 | Nintendo Super NES Console
How to install china mobile software
Computer Monitors
With a PC TV Card:
How do I plug in the super nintendo to my computer? I don't know which cable goes into the "out" place.
Computer Monitors
With a PC TV Card:
Oct 26, 2010 | Nintendo Super NES Console
Monitor only works with DVI/VGA adaptor.
if your monitor came with a disk try installing the drivers again you might still have the drivers for the previous monitor you had with your system if not try going to the manufacturers website and getting the drivers and install them
Aug 13, 2009 | Acer AL2016W 20" LCD Monitor
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Dual monitors can't extend desktop
Connecting Two Monitors
Use the cable adapter to connect a VGA monitor and a DVI monitor to the DVI-I connector on the back panel.
When you connect two monitors, the video driver will detect this connection and activate the multimonitor functionality.
This is the only way to enable extended display. If you use a standard splitter and connect two DVI montors, the display will only be mirrored.
Detailed documentation is available at http://support.dell.com/support/edocs/systems/op755/en/UG/HTML/ultrasma.htm
Hope this helps! Please rate your feedback!
Mar 02, 2009 | Dell Optiplex 755 Ultra Small Form Factor...
Can I use an Apple M7649 Studio Display with a MacBook Pro
Do you have the black unibody Macbook Pro that was just released, or the silver model?
Since the display is DVI, it will directly hook up to the silver model. If you have the new model, you need a mini DVI to DVI adapter.
Nov 22, 2008 | Computers & Internet
HP f2105 21" LCD Monitor Logo
117 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
