Question about Electronics - Others
Lifebox have been having the same problems already mentioned, crossed files, files not showing up etc, so decidede to upgrade the firmware from Maplins site, as suggested in other forums Followed instrutions , and now cannot see anything in TV mode, just a blank screen, when connected via usb to computer all is fine Apart from throw it away, is there anything that can be done thanks
  • 3 more comments
  • kingneptune Feb 06, 2008
    same upgrade now blue screen
  • stevew1 Feb 07, 2008
    you need to type properly, cant ever understand what you;ve written !
    there is a problem with this and maplins know about it, the firmware fix is on there website, and does not work, this is what causes the problems , no tv mode
    sorry to the person b4
  • raftaff Feb 09, 2008
    same problem exactly as stevew1.  not happy!!
  • stevew1 Feb 17, 2008
    send it back from where it came from, mine is, and no problem with that
    seems there is a big problem with this unit, everybody knows about it, but its still being sold
I have the opposite it works on tv but not on pc.
Posted on Nov 04, 2008
Take it back i did, it wasnt a problem,
Posted on Oct 01, 2008
Had a 250 gig lifebox in august 2008 no problems at all it's great, only looked here to see if there was a firmware upgrade not that i really need 1
Posted on Sep 30, 2008
I spoke to maplin technical support and they said its not repairable as the firmware will now be locked.  But they are happy to replace them.  If you purshased it with a hard drive installed, then this will also have to be returned so back up your data elsewhere.
Posted on Feb 17, 2008
Since I got my media storage, nothing shows on my TV. Like one other user said, everything seem to be fine from the pc but when it is connected to the TV, nothing comes up.
I need help!
  • 193 Answers
Ok 1st back up the old settings the solution might be faster .. and more u upgread teh more ur get far frome wen done...the problem might be frome the format try difregmenting then make a surface scan and try again..and if these tasks dident succes u must format it..but u do it in this way...go controle pannel,administrative tools,take the icon of ur pc,and click on th esecond option and then the 3rd..and u will see it...just right click and format..and try again
Posted on Feb 07, 2008
  • mike nasr Feb 07, 2008
    stevew1 i am not an anglais or i talk a low level..but these tips r way u try scandisk and diffragment if the task did not work proparly ur hardwear is a bit damage or have bad or overrighted clusters , u must format 2 recover or spend 3 weeks bying recovery disk so go 2 controll panell in administartive tools...
Install XF2 Firmware V4.10
After you have downloaded the file "install.img" from,connect it to your TV,go to Settings,then System Upgrade,press OK to show the sub items of System Upgrade, choose "Cancel" to abort the operation and choose "Upgrade" to upgrade the system firmware. Afterward,
the system will reboot and the firmware upgrade page begin to show. After firmware upgrade completed, the system will reboot and show the language selection page.
Sep 06, 2012 | LG (HXF1N50SB) 500 GB USB 2.0 Hard Drive
My printer (P3005 PCL6) is showing an error 49.4C2D. However, it is printer may four pages that is after I switch it on and off and eventually it stops. Please help me
HP describes these as 49.XXXX errors (without the suffix numbers after the . (dot)). The general description is that a critical firmware error has occurred, but it's usually not firmware, especially if the printer has been fine until recently.
Usually it's corruption in the print stream for a particular print job, so it could be the program (does this happen with print jobs from a particular application or from all applications; have you installed new software or upgraded it recently for the application that causes the error if it's always the same application?), the driver (have you recently upgraded it?), data corruption in the connection to the printer (bad network or USB cable, etc.), or maybe the firmware.
If they're random, and you can clear them and bring the printer back to ready by clearing the print job out of the spooler, turning off the printer, then turning it on again, it's most likely corrupt data in a print job introduced by one or more of the factors above. If they're infrequent and not too much of a bother, you can just do that.
More information - here's an HP support document on troubleshooting 49.XXXX errors:
Sometimes but rarely, they can be corrected with a firmware upgrade IF your model's firmware is flashable, and IF the problem is in the list of fixes.
Approach upgrading firmware cautiously since a firmware upgrade that doesn't install correctly can render the printer inoperable until you replace the firmware dimm with a new one.
To check for an available upgrade, go to
Click Support & Drivers.
Select "Download drivers and software (and firmware)".
In the text box, type your model, ie: laserjet 2420d in your case.
Click the arrow button to the right of the text box.
At the next screen, pick your specific model if it's not already selected.
At the next screen, If a link named Cross operating system (BIOS, Firmware, Diagnostics, etc.) is there, the firmware is flashable. Click it.
If it's not, you would have to buy a new firmware dimm from HP to upgrade the firmware.
Important - At the next screen, do not click on the Download button. Instead, click the named link for the firmware for your operating system.
At the next screen, select the Read me tab. That contains all the information from all tabs.
Important - The cautious part: Look for your specific error in the Fixes list in the Readme tab information. If it's not there, I'd recommend not installing new firmware.
You can also contact HP directly for help. Just click your country here:
I understand they now charge for phone support, but that chat and email support are still free.
if my solution is helpful you then give me thumb
Jun 24, 2011 | HP LaserJet P3005 Printer
Samsung sf-650 intermittently sends a blank page
Print configuration report "Menu>Reports>Configuration/System Data"
Check the firmware version. 1.07 or lower is likely to have this problem
Upgrading the firmware is quite simple.
Get the update from samsung website>Support>Search Box "SF-650">on product support page find tab "firmware" and download upgrade file.
If you feel competent to do the upgrade (read the instructions in the txt file twice) do it.
Be aware that the upgrade will likely want to do a memory clear once it is complete so you will loose address book etc. Also do not power off unit during upgrade or you will damage the firmware and possibly make the unit unusable.
Hope this fixes the issue.
Feb 21, 2011 | Samsung SF650 Plain Paper Laser Fax
Feb 16, 2011 | Samsung SF650 Plain Paper Laser Fax
My samsung dvd writer is reading cds but not dvds what should i do
Caution: Samsung is not responsable for problems during the firmware upgrade.
When you encounter problems during the upgrade, please contact a Samsung Service Center.
If your drive is still in warranty please contact your retailer first. When you upgrade your firmware, please check the "Buyer" on your label of drive.
If you upgrade wrong firmware, you will have a problem in operating.
ex) SM-332B/*** 63BT123456 F/W=T403(***=Buyer)
■■ How to upgrade firmware ■■ 1. Download the attached "Bin file(firmware)" and "Sfdnwin.exe file(download
program)" into a temporary folder. 2. When you run "Sfdnwin.exe", Pop-up window will appear. you can see your ROM-
drive(s) in the Pop-up window.
Then choose the drive whose firmware you want to upgrade.
ex)Drive:SAMSUNG CD-R/RW SM-332B/T403 3. You will see three icons on the top from left.
If you click the first icon from left, you can see "Investigation window" then open
the firmware file that you already downloaded to the temporary folder. 4. You will see the message" Ready" after finding the firmware file that you want.
Then click the middle icon on the top of left. Then your firmware will be upgraded
automatically. 5. When you finish upgrading firmware , reboot your pc automatically.
■■Sfdnwin.exe : A program which can make your drive download our firmware(s) in Windows.
(It's for only Windows)
I had the same exact problem and thought the ROM was broke but it still played CD's. It's funny because when the problem started I thought I had really messed something up, and it turns out there are massive forums like these for the exact same problems. I hope I can ease a few minds w/ this. I'm running Windows XP, 1G ram, 100GHD.
Jan 31, 2010 | Samsung SD-616 (cddvd-40081) DVD Drive
Lifebox (Maxtor) 250G Med device and Mass Storage
Please backup all of your files in your Lifebox to your computer and format the Lifebox to a FAT32 file system. If you want to know why this problem seeks you... NTFS file system cannot be read in other kinds of devices such as TVs, Cameras (New ones maybe) and more! So if you want to watch DVDs on your TV you better format your drive to a FAT32 file system.
Hope this helps!
Jan 24, 2008 | Electronics - Others
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
A problem with turning on . . .
This firmware upgrade only works with Creative MuVo Micro N200 players. Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware. Back up any audio or data files in your player to your computer before upgrading the firmware.
Before installing the firmware, please complete the following procedures:
  1. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe.
  2. Connect your player to your PC.
  3. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications.
  4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen.
To install the firmware for your player, follow the procedures below:
  1. Download the firmware update, MuVoN200_PCFW_LF_1_20_04.exe to your hard drive.
  2. Connect your player to your PC if it is not already connected.
  3. Double click the firmware upgrade file.
  4. When prompted to set your player in Recovery mode, disconnect your player from your PC.
  5. Remove the battery from the player, press and hold the Play button while connecting the player to the USB port.
  6. Continue to hold the Play button for about 10 seconds after your player is connected to the USB port.
  7. When the Find New Hardware dialog box appears on your PC screen, release the Play button.
  8. If this is the first time a player is installed as Player Recovery Device, Windows will find a Player Recovery Device (or USB Device), and prompt you for drivers. Click on No , and select Do not search. I will choose the driver to install. Windows will install the necessary drivers automatically.
  9. Double click on the downloaded firmware again (MuVoN200_PCFW_LF_1_20_04.exe) to update the player's firmware.
  10. During the firmware update process, make sure to check the box next to Format Data Area under Download options.
Jan 27, 2007 | Creative Labs MuVo Micro N200 MP3 Player
Electronics - Others Logo
365 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
