Slow or no spin
Whirlpool washer in 'Laundry Center' LTG6234DT1 spins very weakly, can stop with hand. I was told to change the belt, but the diagram I viewed on Sears Parts web-site shows that this is direct-drive to motor. Can you help?
  • 167 Answers
It's direct connected to motor!!!
Solution is to change brush which go on collector!!!
This is inside the motor!!!
It's not so complicated to do but must be carefully!!
good luck
Posted on Jan 29, 2008
The washer drum on my Kenmore Laundry Center Electric washer model 98802 does not spin. How do I access the belt assembly?
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer the way my advice is free cuz God is good!
Mar 31, 2015 | Kenmore Washing Machines
Top load frigidaire washer will not spin, it agitates, it drains
You need to replace the starter cap on the motor this is why it will not turn and the smell is the cap that's not starting the motor it also will hum.
Dec 29, 2013 | Frigidaire FFLE2022MW Electric...
Whirlpool duet banging on spin
with the door open,take your hands at 3 and 9 o'clock in the drum and try to move it back and forth,then try 12 and 6 o'clock try moving up and down if you can move it either way,the spider that holds the drum is broken behind the drum and needs replacing
Apr 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool wtw5tesvno
Whirlpool washers are available in many colors and with different options, including various tub sizes, front or top load styles, a fabric care system, high efficiency wash features and energy, time and water sensors. The washers may be purchased in department stores, home repair stores and online. Many are Energy Star rated. However, the washing machine may malfunction occasionally and not agitate or spin. If this occurs, some troubleshooting steps may be useful in solving the problem.
1 sure the washer has electrical power and is connected to a grounded electrical supply. Replace or reset the circuit breaker or fuse if needed, particularly in event of a recent power outage. Make sure the washer lid is closed tightly before use; the washer won't work if the lid is open.
2 void selecting the following cycles: "Extra Low,, "Low," "No Spin", "Delicate," "Casual/Perm Press" or "Hand Washables." All of these cycles use little to no spinning or agitating during the cycle. Select the highest possible spin cycle for the fabrics being washed.
3 pen the washer lid and redistribute the load; unbalanced loads may cause the washer to stop or slow down. Add additional items if only one large item,
such as a rug or blanket, is in the washer.
4 Use only the recommended amount of laundry detergent, as excess sussing can reduce the overall spin speed or cause the washer to stop agitating. If the Whirlpool washer is a high-efficiency model, use only high-efficiency laundry detergent.
5 Examine the drain hose and straighten if kinked. Remove any possible obstructions and ensure the end of the hose is no more than 96 inches from the floor, as this will cause water to flow back into the washing machine.
Nov 13, 2011 | Whirlpool Washing Machines
Started normal cycle then gets to drain and spin clothes are still wet
Hello there:
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt, a worn clutch , or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. then retry ok
Oct 07, 2010 | Whirlpool Washing Machines
Washer spins but not enough to extract water from clothes or tub.
could be a loss belt or a kinked hose, since you say it feels weak i would think it is not getting up to speed which would be a loss belt or drive train issue, of course it could just be to big a load or on slow spin speed setting
May 22, 2008 | Washing Machines
Slow spin on Whirlpool G6234DT1
check the belt, it must have gone loose. it can be replaced. but remove the belt and take it to the hardware store for a exact replacement.
Jan 27, 2008 | Washing Machines
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
