Split System Air conditioner
Why would my air condtioner be leaking from the wall unit?
  • fixya768 Oct 29, 2008
    My wall unit has a plastic box in the wall and the drain pipe drains into this box. is this correct? the box has two open drains on the left and right inside, I  gets a damp patch on the right side. do i block the drain in the box or join the tube from the air con unit to the left drain in the plastic box in the wall.
  • Anonymous Mar 31, 2014
There normally two types of leakages from the wall unit.
1.The warm air in the room when comes in contact with the cooling coil of heat exchanger (consisting of fine fins where compressed refrigerant evaporates) looses its heat & cannot retain the same moisture content at lower temperature at the point of contact with evaporator. There is a provision of a drain pipe to carry this condensed water to outside water drain. So if the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
2.The second problem can be the leakage of the refrigerant. If there is second type of problem, then there will be very little or no cooling irrespective of continuous running of air conditioner. This can be easily checked by feeling the temperature of outlet air from the air conditioner.
Conclusion-As you have written that there is leakage from the air conditioner, but you have not written whether it is visible or invisible. If the leakage is visible, it is problem number 1 & if it is invisible, it is problem number 2.
If you are not satisfied you are free to ask for more explanations.
Posted on Jan 29, 2008
  • 236 Answers
If it is water leaking check the indoor drain pan if overflow with water.If the pan is overflow with water then you need to clean your drain pan and drain pipe. While the unit is operating check the drain pipe if water drip, if no water coming out from drain pipe you need to flush it with water to flush out the restriction.
Try also to check if no icing build in the evaporator fins. If icing is present then you need to clean your indoor evaporator pins and air filter. But if it is clean and still icing is present then your unit is out of gas.
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
Need a new remote
I would contact your local LG. Also many electronic places sell universal ac remotes (check the packaging to ensure that it can control LG's). The universals are cheaper and easy to set up (they come with step-by-step setup instructions). Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | LG Art Cool LA121CNP wall/window Air...
Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Jan 16, 2010 | GE Quiet-Aire Ductless Split System Air...
Mitsubishi split system will not start no green ligths come on on wall unit
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
Jan 09, 2010 | Mitsubishi MS-A09WA Split System Air...
Conia 3 HP, 5 yr old air con/ condensation from wall unit
Nov 30, 2009 | Heating & Cooling
Water leaking out from wall mounted head unit.
A little too vague, but probably the evaporator drain is disconnected, plugged up or was never installed.
Nov 10, 2009 | LG Art Cool LA091HNP Split System Air...
MY split ac is leaking water from the wall unit, it has been doin
Usually an AC unit builds up condensation. If you have a drain hoole or hose that is clogged up therefore not allowing the build up to drain off it will spill over the top of whatever housing the condensation goes into. If you can look for that issue first.
Aug 03, 2009 | GE Quiet-Aire Ductless Split System Air...
My air condtion blow some hot air with vabrait what shall i do ?
you need to recharce your air conditioner system with refridgerant. you may have a small leak that depletes the system over time.
Mar 16, 2009 | 1999 Daewoo Nubira
Split HVAC does not achieve requested temperature
If is heating on outside temp must bee max 5 degree
Celsius.If leak inside unit then check drain hose.
Feb 15, 2009 | Mitsubishi MS-A09WA Split System Air...
drain line is more and likely stopped up
Dec 02, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
1,471 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
