Question about Zanussi F1045W Front Load Washer
Zanuusi brushes My drum wont rotate on my zanussi washing machine. I think it is the brushes would this be right? Could I fix them on my own
  • 126 Answers
I'm pretty sure that it is the brushes;) It's pretty easy, but you must know what you are doing:)
Posted on Jan 29, 2008
Zanussi turbodry wdt 1075 washing machine fills & drains but does not perform wash cycles or spin cycles drum does not rotate
Quite probably the motor brushes. Disconnect from mains. Tilt machine backwards as far as possible. On motor, disconnect wires to brushes. With a multimeter, check continuity between brush and any segment if the commutator. If open circuit, replacing the brushes should do the trick. Also visually examine the commutator for damage
Aug 17, 2014 | Zanussi Washing Machines
My Zanussi fls 1183 is not washing the clothes, they are not completely wet and are not clean
This usually means that the drum is not rotating during wash or spin.
If this is the case the most common causes are a broken drive belt or the motor brushes worn out
Always remove the plug before investigating
Jan 22, 2011 | Zanussi Washing Machines
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Oct 06, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi FS 1355 w Drum not turning
DEFF BRUSHES.JUST HAVE SAME PROBLEM MYSELF NOW AND TOUCHED BRUSH HOLDER SLIGHTLY AND RESTARTED..
Jan 01, 2009 | Zanussi FS1455W Front Load Washer
Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Sep 12, 2008 | Zanussi ZWF1440 Front Load Washer
I have FLS 1183W Zanussi washing machine. The drum no longer rotates and does not spin. Rgds
check motor brushes for continuity (you will need a multi-meter for that) or instead, take the brushes out and examine them. this is the usual cause
Jun 21, 2008 | Zanussi Washing Machines
Zanussi washing machine drum will not go round at all
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Apr 08, 2008 | Zanussi ZWF1430W Front Load Washer
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Zanussi F1045W Front Load Washer Logo
138 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
