Question about Sony Ericsson W550i Cellular Phone
Technical support my cell phone can't be started when switched off,if i have to do it then i have to take out it's battery and replace it again.
  • bababit Sep 24, 2008
    thnx a lot fr tryin prob not solved fully but has reduced a lot
  • 4 Answers
There might be some dust problem or the software has corrupted. Please get it dusted from inside, it will start working properly and if this does not work then go for software part
Posted on Feb 03, 2008
Software problem
Posted on Jan 31, 2008
5800 phone will not switch on
Check the battery voltage and if this is low check if the adapter is working - check the voltage at the pin of the adaptor.
If absent then replace adaptor.
If not replace battery and switch on . If the phone does not boot there are issues in the mother board and could be related to the hardware which will require technical help from Nokai support.Get estimate or if under warranty claim for it.
Aug 03, 2011 | Nokia 5800 XpressMusic Smartphone
Phone got accidently wet and is completely dead...will it start working again or is there anyway of getting it going again
First of all do not switch on the phone unless it is completely dry. If you switch on the phone before that there are chances that it gets short circuited .
I would recommend if you can take the phone apart and put the circuit board and display components near to slight wave (like keeping it near an glowing bulb) etc.
If it still does not start working you may require technical inspection into the same.
Jun 27, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Battery is charged up....i tried to switch it on and it cant ......
power switch maybe damage and need replacement
it might be a hardware problem (technical matters)in this case, bring it to a service center.
please rate me....thanks
May 31, 2011 | Nokia N70 Cellular Phone
My samsung cell phone keeps turning on by itself over and over. how do I stop this?
You can remove the battery, let it rest a while and insert it back and switch on the phone again. Should you face any of the same issue it would be best to bring it down to the nearest samsung care center for technical checks.
Mar 05, 2011 | Samsung SGH-L700 Cell Phone
My Nokia 3110c Mobile was switched off automatically, when i try to switch on, light is on for few seconds and same happends for three time and become switched off
Sounds to me like your phone battery is empty or damaged. Try to fully charge the battery and then try to start the phone again.
If that doesn't work, you will need a replacement battery - try ebay.
Aug 06, 2010 | Cell Phones
2nd attempt----my a930 cell phone continues to discharge prematurally. Can get only a 2-4 hour charge. Batteries have been replaced. Do I need a software update ??
1. What type of battery do you have is it a Lithium Ion or Ni Cad battery, Ni Cad batteries need to be completely discharged and then charged back up again, if its a Lithium Ion, your battery has memory cells in it, where it technically doesn't matter when you do it...but
2. Charging habbits - How are you charging your phone, you should charge the phone when you first get it for a good 8-10 hours, the first charge is the most important, after that depending on what type of battery you have (see above) let it die and then charge it up for about 8 hours again, do this for about a week you should start to see significant difference.
Also are you using a car charger or a wall charger, car chargers are NOT the best way to charge your phone, they used to get the job done, but not a perminate solution
Apr 06, 2010 | Samsung SCH-a930 Cellular Phone
I ALSO HAVE THE SAME
Hi Friend,
Please follow the below steps,
1.Switch off the mobile.
2.Remove the battery,sim card and the Memory card
3..Hold the Switch ON button for 20 secs
4.Replace the Battery and the Sim card after 20 secs,
5.Now switch ON the mobile .
6. after it has ON check it wither its working then replace the memory card
Regards,
Ayyasam
Aug 27, 2009 | Nokia 6030 Cellular Phone
Can not send messages messages stay in outbox
I've just had this problem today and couldn't find any advice either. My battery was low and 'sent messages' box was fairly full. I charged it up, emptied the sent box, switched phone off and removed battery. I took sim out and gave it a wipe before replacing it. Switched it back on and it's working again! Not very technical, I know but it seems to have worked! It's driven me mad all day! Hope this helps????!
Aug 13, 2009 | Sony Ericsson K660i Cellular Phone
Sony Ericsson W550i Cellular Phone Logo
32 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
