Question about Intel Desktop Board D845WN Motherboard
No power to motherboard
I have a Intel D815EEA motherboard that I'm installing. But when I turn on power, processor is on and theres power to the hdd,and dvd-rom. But nothing else.
  • Anonymous Mar 14, 2014
    two beeps on motherboard for intel D815EEA
  • 119 Answers
If there is no power to the motherboard then there would be no power to anything else. I can only assume that everything (HDD and DVD Rom) comes on but your monitor remains blank when power is turned on. How do you know that the processor is on? Im guessing that you assume because the cooolant fan starts turning then there is power to the processor. Unfortunately that is not the case. Your Processor could be the problem try changing it. should the speakers be emitting beeping when the computer is turned on then try changing your memory (RAM). If none of these are working then try installing a VGA card into one of your PCI slots and plug your monitor on the VGA card. If none of these work then you Mboard needs to be replaced as it could be damaged. let me know how it turns out then I will let you know what to look for in terms of damages. thanks
Posted on Jan 29, 2008
Hello .i want know where power led and sw wire go connect on a emachine T3626 i desconnect my self and i forget where the go please help me
If you do not have pdf viewing capabilities, your browser will prompt you to install the plugin, please allow this install once you've followed the above link. In the pdf document, refer to table 48, on page 71 for how to connect your front panel.
Nov 22, 2010 | Zerus Intel Desktop Board D815EEA...
GPA Card for D815EEA ? What is the best performing GPA Card I can install on this motherboard for the money?...minor gaming (Diablo) and some AutoCAD 2007. Nothing 3D. I have a 25" HDMI monitor as well....
Something like this
Everything better will be held back by your pc.
May 08, 2010 | Zerus Intel Desktop Board D815EEA...
Unable to find the power switch to connect to
If you no longer have the manual for you're Intel D815EEA motherboard, open the link provided and download it;
You will also need Adobe reader installed to view the manual;
Read over pages 65 to 68.
Once completed turn to page 68 Figure 23. Front Panel connectors. Figure 23 shows two views.
View - (left figure), shows J9C1 as you look down at the front panel pins. The right figure will not be needed. Connect each jumper or each pair as shown.
Wire colors are important and do vary from case to case. The common color of each pair will most likely be used for negative. Wire colors such as blue, light blue, green, light green, red and light red are commonly used as positive.
Pin 1 will be positive and pin 3 will be negative. This is letter - C. Hard drive activity LED.
Pin 2 is positive and pin 4 is negative. Case power LED, and so forth.
As mentioned on page 65, the case front panel pins use 5 volts DC. If you make a mistake and place a jumper backwards (No LED light), just power off the switch on the back of the power supply and correct the jumper by turning it 180 deg. If you’re case’s LEDs do not light up than you will need to connect letter G and letter H. The electronic circuits under the motherboard should supply all 16 motherboard pins with the 5 volt DC and ground needed.
Feb 28, 2010 | Zerus Intel Desktop Board D815EEA...
I can not find the matching pinsforthepwsw hdd led
Open the Intel link provided;
Create a folder on your desktop and name it, Intel D815EEA
Download the file named, "" in to your Intel folder. The *.zip file must be uncompressed. You can download and install a 45 day free trial program called WinZip. Download WinZip from here; the program named Winrar will also uncompress the file;
Once the either program has been installed open the Intel folder. Right click once on the file *.zip and from the pop-up window and click, Extract Here. You will need Adobe reader to view the PDF file. Adobe is free;
Open the PDF folder. Open the "A1696401.pdf" file. This is the manual for your D815EEA board.
Open to page 69 motherboard layout. Item "C". Find pin 1. You can zoom in with Adobe by clicking the + sign in the tool bar. Than go to, Table 48. Section page 71 in Adobe.
Front Panel Connector. Example:
Pin 1 is power for the HD_PWR = Hard disk drive, Power LED. Pin 2 is ground for the HD_PWR. ECT...
Case wire colors vary. Normally the solid colors red, green, blue and green are positive. Except black which is usually ground for the internal speaker.
The wire color solid white is usually - negative. So each pair will have a common wire color used for negative.
Hope you find this helpful.
Oct 17, 2009 | Zerus Intel Desktop Board D815EEA...
How to cnnect the light cables Power and reset............etc of intel mother Board d815EEA
Connector number J9C1 - power LED pin 2-4, reset switch pin 5-7.
1-3 - hard drive activity led, power switch 6-8 pins.
Connect and enjoy :-)
Aug 10, 2009 | Zerus Intel Desktop Board D815EEA...
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
How to connect Power LED, Power SW, Power Reset and HDD LED
it is written in the motherboard..
re-reset botton
pw- power botton
hdd led- hard disk led
pw LED- power led
the code is pin 1....
Jan 28, 2009 | Zerus Intel Desktop Board D815EEA...
Try to remove the battery so it reset the bios and then power it up.
Jan 26, 2009 | Intel Desktop Board D815EEA2 Universal...
I need a pin diagram.
pin diagram of motherboard....?which model...
Jan 07, 2009 | Zerus Intel Desktop Board D815EEA...
Intel Desktop Board D845WN Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
