I have a fax number but dont know how to connect it to the fax michine
Do you have separate phone lines for fax and phone?
If so, connect it to the fax socket (like the telephone socket) on the wall.
Use the menu button to setup the date, time, your fax number etc.Faxes can be sent even if you don't do this, but the details printed on the receivers copy will show wrong date, wrong time and wrong fax number
If you have only one line for phone and fax, you may have to select the one of the options preferably phone/fax, connect it to the wall socket as you would connect a telephone
Read your manual for for other fax report and so on.
luciana44
Jacki
Must have DSL filter attached before fax, not sure how you are saying you have it setup, but phone line should come from wall then to filter then to fax socket marked line, phone should be hooked to socket on fax marked EXT, if you dont have dedicated fax line then fax number will be same as phone no.
If you have Adsl then there will be a lead from wall that splits into two, one goes to your modem (ADSL) and the other marke phone or line needs to go to fax socket marked LINE
The machine will print out whatever fax number is programed into its memory not what line it is connected to.
Plug a standard phone into the socket that the fax uses and ring your mobile..
or if just dial your mobile from the fax (type in numbers press send) should see caller id on mobile
I think maybe your setup is a little more complex cause the T632 normally is just a laser printer but you must have the 3100 MFP Option.
manual link
http://www.lexmark.com/publications/pdfs/lexmark3100/eng/userref.pdf
