Question about SAMTRON 55V 15" CRT Monitor
My monitor is not working sometimes
When I turn on my monitor I hear a ticking sound and the power led is lit green and flickering but the monitor is blank, but after keeping on trying it, it works until I switch it on again. this started after a power failure.
Your help will be greatly appreciated
from Steven
  • 2 more comments
  • Simranjit Singh BEdi
    Simranjit Singh BEdi Feb 03, 2008
    i too having same problem please help me my samtron 55v monitors first give sounds kriccchhh kkkrrrrrrich krch and the next time i power on its dead no green light, also it gives foul of burning smell from last two days before all this happen.
    please mail me the solution to overclocker13x@yahoo.com
  • Anonymous Feb 17, 2008
    When I turn on my monitor the power led is lit green and flickering but the monitor is blank, but after keeping on trying it, it works until I switch it on again. this started after a power failure.
  • Paul Teichmann May 11, 2010
    It sounds like the power failure may have been preceded by a surge that may have pushed some of the circuitry to the brink of failure. Usually it's the Horizontal scan Transistor that works hardest, but could be other things, too. If you're not into fixing the problem yourself, it's time to look for another monitor, as it would probably cost as much to fix it as to get a new one.
    Hope that helps!
    Problem Solver:
  • 10 Answers
I think that problem from eht [fbt] trasformer. i also.face that problem
Posted on Feb 12, 2008
17" flatron crt monitor only green led blinking and tick tick sound .No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | LG Flatron F700P 17" CRT Monitor
My lg studiowork 700s has stopped working
look listen and dance not matter how you performance keep it calp and trust it
Feb 20, 2014 | LG Studioworks 700S 17" CRT Monitor
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Have a phillips 107s monitor, green led flashes, making a tick tick sound, no display
Make sure the mains plug is firmly inserted. The most likely cause of the problem is a power supply problem which will be uneconomical to repair in the current day. Cheaper to replace with an LCD.
Sep 28, 2009 | Philips Standard 107S 17" CRT Monitor
Aoc 5en no display
I alreeady encountered this problem. I fix it temporarily.... I just turn it off, Press all the Function btn and the recall btn, then pres the On btn... wait for 2 sec then release the func, recall btn. Then I already able to use the PC for about o hours without interrupted signal (on/off). I call it temporary fix because whenever you turn off the Monitor, you have to do the same process again..
Try it it can help.. Thnaks.... If you already find solution , maybe you can share it to me too .. Thanks..
Jun 25, 2008 | AOC 5 En 15" CRT Monitor
Troubleshooting Viewsnic Monitor
My ViewSnic 175b monitor goes black after about 1/2 hour working. In addition the words/letters typed after the blackness do not appear in the text input box.
This started happening after my last ZoneAlarmSuite Update and virus scan last Friday. Prior to that no problems at all. Any help gratefully recieved.. ...
Jun 05, 2006 | ViewSonic VE175b 17" LCD Monitor
SAMTRON 55V 15" CRT Monitor Logo
119 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
