Question about Casio Cassiopeia E-100 Pocket PC
Tranfer problem I can tranfer wordpad documents onto my old Cassiopia E 100 fine, but bringing the file back to the computer desktop and the file is corrupted and unreadable. Text files created on the E100 are also corrupted. Any ideas?
  • 551 Answers
SOURCE: cassiopeia E100, is there anyway to view excel files?
Yes there certainly is. Get SpreadCe programme from ByeDesign. It can handle .xls files upto & including Office 2K in native format. Have no experience with Office XP. As a matter of fact I find it better than Pocket Excel included in CE 3.0 and later. I store my files under My Documents folder on the CF card using a USB card reader/writer. Hope this helps.
Posted on Sep 04, 2005
0 characters
1 Points
I have an old workpad IBM C3, I would like to transfer all my data on my new windows 7 computer. What shall I do? (It worked with windows XP but I don't remember what I did to install a driver pilot)
You need to download the Desktop manager and Hotsync for your WordPad C3. For your old device, you'll need 4.1.4.
Palm Software: (you may have to run it in WinXP compatiblity mode)
User manual:
Good Luck..............
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 02, 2011 | IBM WorkPad c3
Psion Revo replacement restore
What do you do if you no longer have access to a Psion, but need to access some data from an old Psion backup on your PC? Native Psion files can't be read on a PC, but fortunately, there are some solutions:
  • Use the PsiWin PC connectivity suite to convert the Psion-format files to a format that can be read on the PC.
  • Download and install the Psion ER5 emulator - this gives you a Psion machine on your PC, and will allow you to access your old data on a PC - See our emulator setup page. From the emulator, you may be able to print or export your data to a text file, or use a third -party Psion converter
  • Consider borrowing or buying an old Psion machine, loading the files onto the Psion, then printing the documents or data as a text file
  • Find another friendly Psion user that may be able to convert the file into a format that can be read by a PC for you. If you don't know of another user, try asking for help in our Psion forum
Data conversion for the Psion can be quite complicated, due to the file formats used by Psion / Symbian. You should find that the PsiWin program supplied on CD with your Psion machine can help you with most of your conversion needs. If your PC is connected to your Psion, dragging files from "My Psion" to the PC should prompt you to convert to a PC format, otherwise you can convert files that are stored on the PC, using the Psion File Converter. This program is installed with PsiWin and is located in c:\program files\Psion\PsiWin - the application filename is Cpycnv.exe
psiwinconv.jpg For more help on file conversion, see our dedicated conversion page.
Agenda and Contacts databases: Note that these can't be converted using the Psion File Converter - PsiWin supports synchronisation of these files, but not direct conversion. See our suggestions in our Backup FAQ. The most common solution is to load up the files in the Psion Emulator, and either use Print to save the data as a plain text file, or use a Psion-based converter, as detailed on our Conversion page
Sep 17, 2008 | Psion PDAs
How do you install downloaded programs on the Dell Axim X30?
Downloaded programs can be installed onto the Dell Axim X30 using Microsoft ActiveSync. Microsoft ActiveSync can be installed onto your computer using the Dell Companion CD which came with your Axim X30.
Once Microsoft ActiveSync is set up on your computer, if the program you downloaded came in an installer file, then double-clicking on the file will start the installation wizard and the software will be automatically transferred to the Axim.
If the program you downloaded did not come as an installer file, then double-clicking it will bring up an error message. In that case, use ActiveSync Explore to copy the program file to the Program Files folder on your Axim.
Mar 05, 2011 | Dell Axim X30 Pocket PC
Can't hotsync replacement t5 ; I dropped my working T5 and have not been able to hot sync my backup unit.
If the new one won't pick up your old files you need to go onto the desktop app and export the data. then create a new id on the new palm. It should now hotsync with the new blank id. Now go back to the desktop and import the files from the other id. Hotsync again and you should have them on your palm.
Mar 19, 2010 | Palm Tungsten T5 Handheld
Iwant to do file transfer with my computer so plz help me out
exactly what do u want to file transfer with ur computer there are several file transfers with your pc such as instant messaging, ipod music tranfer etc.
Mar 03, 2010 | HTC Touch P3450 Smartphone
Problems to manage docum+media in a Blackberry 7100 v4.0.0.219
Hi, You can install latest version Desktop Manager 4.7. You can download the software from Latest version Desktop Manager will give you more options and it will help you while you are using the application. I hope this information will help you
Aug 19, 2009 | RIM BlackBerry 7100G Smartphone
I cant transfer pictuers and videos to my n81
connect usb to pc and go to my computer you'll see removable drive e or f click it...and make a new folder but save your desired files first on desktop or my documents ok---a-jay cute
May 07, 2009 | Nokia N81
Lg ku990
Do you mean you want to tranfer audio files or music files from your computer to your phone so you can enjoy music on your device? If so let me tell you that BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • Sep 04, 2008 | LG KU990 Viewty
    Palm T/X won't hot sync on Window XP Media Center Edition
    i had that problem too. sorry it is bugging you.
    i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
    on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
    as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
    please let me know it that worked for you. i still have some suggestions
    good luck and enjoy
    Nov 05, 2007 | Palm TX Handheld
    EM-500 music transfer
    Seeing that you are using a EM500 with only 16mb of RAM, you might want to get a SD/MMC Card. With that being said, let's do this, shall we? Connect your PPC to your desktop using ActiveSync, then press on the TAB "Explore" then "My Pocket PC". You are interest in the "My Documents" folder, that is where you will place your .WMA, MP3, OGG files. Just copy the music file from your desktop that you want on your PPC, and then paste it to the "My Documents" folder of your PPC. Now if you have a storage card (MMC/SD), you will have to create a folder on the storage card and name it to "My Documents". So you will then have 2 My Documents folders, one on storage card, and 1 on the PPC. If you want the Music file on the storage card to save space on your PPC, then do the following. Connect the PPC to your desktop using activesync, then press on the TAB "Explore" then "My Pocket PC". You then need to click on the "Storage Card" folder, there you will see your "My Documents" folder you created. Just copy the music file from your desktop that you want on your PPC, then paste it to that folder. To speed things up, you can also use a MMC/SD Reader. you can then copy and paste directly on the memory card, without going thru ActiveSync. Goodluck, and have fun!
    Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
    Casio Cassiopeia E-100 Pocket PC Logo
    19 people viewed this question
    Top Casio PDAs Experts
    Are you a Casio PDA Expert? Answer questions, earn points and help others
