Question about Toshiba Satellite 2410-S203 Notebook
Wireless switch I installed an Intel mini-PCI WI-FI card inside my TOSHIBA Satellite S2410-303. It works fine, but there is no way of switching the wireless card off through the wireless switch on the right side of the PC. Neither the hot key Shift-F8 seems to work. Of course I installed the utility from Toshiba, but to no avail. Any help would be much appreciated. Thanks.
  • 3 Answers
Wireless drivers problem
TOSHIBA Satellite S2410 drivers
http://www.notebook-drivers.com/notebook-drivers/s_255_1.shtml
Posted on Jan 29, 2008
Tip
Toshiba Bios Password Deletion Satellite P100 & Satellite Pro P100 With...
With notebook turned off;
  • Open Wi-Fi Cover
  • Remove Mini Card Wi-Fi card
  • Locate & Short Out JP8 for 5 Seconds
  • Remove short and turn on
  • NO BOOT
  • Press & Hold Power button to turn off
  • Turn on again & password is cleared
Satellite L10, L20, L30 & Satellite Pro L20
  • Open Wi-Fi Cover
  • Locate & Short Out JP1 for 15 Seconds
  • (Satellite L10)
  • Satellite L20/Pro L20 short out G1
Satellite M100 & Tecra A6
  • Open Memory Cover
  • Remove Memory
  • Remove Black plastic insulation
  • Locate & Short CMOS CLR1 for 15 Seconds
NOTE:
All the following models use the same password removal process.
Satellite: 17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70, A80, M40X, M50,M60, M70, M100
Tecra A3/S2, A5, A6
  • The jumper is always located under or near the memory modules
  • Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOS CLR1 (M100 & A6)
Satellite A100 & Tecra A7
  1. Remove Strip cover
  2. Remove 2 x K/B screws
  3. Move K/B Unit up but don’t disconnect
  4. Release & Remove Mini Card Wi-Fi Card
  5. Locate & short C88 Pin 1 & 2 together
  6. Power on Machine while still shorting Pin 1 & 2
  7. As soon as the TOSHIBA logo appears, remove short
  8. If machine boots, Password has been removed
  9. Satellite A100 (PSAA2A-02C01N)
    1. Remove Memory Cover from base of machine
    2. Release & remove right side Memory Module
    3. Lift black plastic insulation
    4. Locate & short PAD500 Pin 1 & 2 together
    5. Power on machine while still shorting Pin 1 & 2
    6. As soon as the TOSHIBA logo appears, remove short
    7. If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1. Open modem & Wi-Fi card cover
    2. Remove mini PCI Wi-Fi card
    3. Lift up black plastic
    4. Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1. Open palm rest cover
    4. Locate & short C5071 Pin 1 & 2 together
    TE 2300
    1. Remove 2 x B12 screws from bottom of system
    2. Remove strip cover
    3. Remove keyboard screws 1 x B2.5 & 1 x SF4
    4. Remove 1 x 4mm screw & Wi-Fi cover
    5. Remove mini PCI Wi-Fi card if fitted
    6. Locate & short points as shown in picture below
    7. Power on machine while still shorting points
    8. Short for 5 seconds
    9. Nothing will appear on the screen
    10. Turn system off holding down power button
    11. Password is now removed
    Satellite A60
    1. Open Wi-Fi slot cover
    2. Lift up black plastic
    3. Locate & short C561 Pin 1 & 2 together
    4. Power on machine while still shorting Pin 1 & 2
    5. As soon as the TOSHIBA logo appears, remove short
    6. If machine boots, password has been removed
    If you need your Toshiba bios password removed and your model is not listed above then chances are it's a procedure that can only be done at an authorised repair centre.
on Jun 08, 2010 | Computers & Internet
What is WLAN 1591 Half Mini-Card?
1pcs Intel 5100 "Half" Mini PCI-E Wireless Card
Standard / Public Version fit in any brand laptop
Intel Mini PCI-E Wireless Card 512AN / 5100
  • Manufacturer: Intel Corporation
  • Manufacturer Website Address: www.intel.com
  • Product Model: 512AN_HMW
  • Product Name: 512AN_HMW WiFi Link
  • Marketing Information: The Intel WiFi Link 5100 Series is a family of IEEE 802.11a/b/g/Draft-N wireless network adapters that operate in both the 2.4 GHz and 5.0 GHz spectra. These adapters, available in both PCIe Mini Card and Half Mini Card form factor deliver up to 300 Mbps of receive bandwidth; in addition to providing a host of features that enhance today's mobile lifestyle.
  • Product Type: Wi-Fi Adapter
  • Wi-Fi Standard: IEEE 802.11n (draft), IEEE 802.11a/b/g
  • ISM Band: Yes
  • UNII Band: Yes
  • Number of Antennas: 2
  • Antenna Type: Diversity Antenna
  • Wireless Transmission Speed: 300 Mbps
  • Host Interface: Mini PCI Express
  • Dimensions: 1.06" Height x 1.18" Width x 0.13" Thickness
Jun 26, 2011 | ASUS A7V333-X (A7V333-X/L) Motherboard
Need drivers for wireless mini lan card for Toshiba Satellite 1900-704
http://www.downloadatoz.com/driver/download_124691,toshiba-satellite-m35x-s3491-intel-802-11b-g-mini-pci-wifi-driver-8-0-12-9000w2.html
copy this url and paste it in your browser and lunch.the download button for your driver will appear for your download.install/run setup.exe after ward and your problem would be fixed.
rate this solution please
Nov 24, 2010 | Intel Toshiba Satellite Mini-PCI Laptop...
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Intel 802.11a/b/g,b/g Mini-PCI Card driver installtion problem
Try updating driver from Device Manager
regards
raj
Jun 28, 2008 | Computers & Internet
Help
u can get it by just googling from net.
but u must be having the driver disk given to u while buying that.
kindly use that
Jun 16, 2008 | Toshiba PA3300U-2MPC - Atheros mini-PCI...
Toshiba Satellite 2410-S203 Notebook Logo
372 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
