Question about HP Color LaserJet 2600n Printer
Fuser error need service manual on how to strip fuser
  • Anonymous Feb 13, 2008
    I have problem with my printer When I power on it showing Fuser error how I can fix this.
  • Anonymous Aug 09, 2008
    The toner light will not go off, the printer is not callaberating
    Guru:
  • 61 Answers
Marca error 922 service fuser lexmark t520
922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
  • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
  • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
  • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine. I suggest you contact Lexmark Technical Support.
  • Aug 23, 2011 | Lexmark T520 Laser Printer
    MY OPTRA SE 3455 IS SHOWING THE FOLLOWING: 921 SERVICE FUSER ERROR
    A 921error indicates that the fuser unit failed to reach the standby temperature.
    • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at. least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
    If you need further assistance please contact Lexmark Technical Support or any Lexmark authorized service provider.
    Aug 12, 2011 | Lexmark Optra Se 3455 Laser Printer
    Lexmark T644 920.16 Service Fuser Error What do I need to do to repair this problem?
    Lexmark gives the following list of all fuser errors and recommends what action you should take (Lexmark Knowledge Base). that the fuser unit failed to reach the standby temperature.
  • 920 Fuser Error message indicates that the fuser unit in the printer is below the proper temperature for printing.
  • You may need to replace the fuser: watch this video:
    http://www.youtube.com/watch?v=RjQkR4x9fqw
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
    Jan 24, 2011 | Lexmark T644 Laser Printer
    922 service fuser error
  • 921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    Nov 10, 2010 | Lexmark T522 Laser Printer
    920.06 SERVICE FUSER ERROR
    A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
    May 26, 2010 | Lexmark T640N Networkable Mono Laser...
    921 service Fuser error
    921 Fuser Error indicates that the fuser unit failed to reach the standby temperature. Leave the printer off for at least 10-15 seconds before turning it back on. This gives the printer's engine board a chance to reset. Make sure printer is plugged in straight to the wall, bypass any surge device or power strips as this can cause a low amperage problem in your printer which can trigger a false fuser error. If this does not help, you'll probably need service on the machine since it deals with the LVPS, the fuser and the system board.
    May 19, 2010 | Lexmark Optra M410 Laser Printer
    925 service fuser error
    A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
    1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
      If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
    2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
    3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
    Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
    50.4 fuser error
    Some suggestions:
    • Turn the printer off for 20 minutes and allow the fuser to cool (this may resolve high temperature fuser errors).
    • Re-seat the cooled fuser assembly (this may resolve other non-temperature related fuser errors).
    • If the printer is plugged into a power strip or surge protector, plug it directly into a wall socket or different circuit (this may resolve errors caused by an inadequate supply of electricity).
    • Try a different power cord (the current power cord may be damaged).
    If still a problem, your fuser is faulty and needs to be replaced (typically not a user-serviceable item) by service. Hope this helps.
    Jul 21, 2009 | HP LaserJet 5000 Printer
    Re: 4037 5e lexmark laser printer printer is showing 921 service what does this mean and how do i fix it
    Here's some info:
    Oct 16, 2008 | Lexmark Office Equipment & Supplies
    LEXMARK T620 FUSER ERROR 924
    Explanation
    A 924.xx error message indicates that an "open circuit" has been detected in the fuser unit.
    What to do
    1. If this is the first time you have seen the error, turn the printer off.
    2. Leave the printer off for at least 10 seconds to give it a chance to reset, then turn it back on.
    3. If this does not clear the fuser error, the printer will probably require service. The parts most likely to be causing this error are the following:
      1st, the fuser unit ( this is the most likely of the three )
      2nd, the system board
      3rd, the low voltage power supply unit.
      These parts will need to be inspected by a service technician and replaced as necessary.
      IMPORTANT!
      If this is an intermittent error, you may want to check how the printer is plugged into the wall. Make sure it is plugged straight into the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in the printer which can trigger a false fuser error. This is true even if the printer has worked on this surge device previously.
    Sep 26, 2008 | Office Equipment & Supplies
    HP Color LaserJet 2600n Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
