Question about Dell Latitude D600 Notebook
WIRELESS LAN SPEED IS 11MBPS WHERE AS I THINK IT SHOULD BE MIN 54MBPS, WHAT SHOULD I HAVE TO DO
  • noorafsar1 Feb 09, 2008
    dear sir,
    thanks for the response!!!
    It is wireless LAN 3 A mini PCI adapter and in its properties setting channel 802.11b is selected
    two radio buttons are available like 802.11b and 802.11a but the other option like 802.11.a is read only and cannot be selected. I can understand what to do
    I will be grateful if you advise me
    trully
    Noor Afsar
  • Anonymous Jan 15, 2009
    same the speed is always 11 for wireless
It appears you are using a 802.11b WI-FI card (either at the PC or the Access Point side). If the card is a 802.11g instead, check out the settings to verify 802.11g is enabled. Regards.
Posted on Jan 29, 2008
  • g_cic Feb 11, 2008
    802.11b is a standard that can reach a (theoretical) maximum of 11 Mbps, whereas 802.11a could actually reach 54 Mbps (working at higher frequencies). Apparently your software could support both standards, but if the 802.11a is permanently disabled, it could mean your mini-PCI adapter only supports the slower 802.11b. I would advise to buy a USB-WiFi adapter, which is not much expensive and would give you the speed of the 802.11a or, better yet, the more recent 802.11g standard, that is 54 Mbps. Take care.
NetGear wireless router WGR614 v6 runs with speed 1 0 mbps instead of 54 mbps
how far away are you from your wireless router when your getting 10 mbps?
Please note that wireless will not guarantee speeds of 54 mbps.
It will dramatically decrease the farther away you or how much interference there is between your laptop and router.
Also check if your wireless router is set to 802.11 G mode. if you have any devices that only support 802.11B you will only get speeds up to 11mbps compared to G at 54mbps
Mar 13, 2011 | Computers & Internet
Will it work with a wireless g router ?
The Play Adapter offers both 2.4GHz and 5GHz band operation, and it is backward compatible with 802.11a/g devices at 54Mbps as well as 802.11b products at 11Mbps.
Feb 04, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
Do I have a choice to run this on N or G? If so, how do I change the setting?
Hi
No,those aren't options for you,unfortunately you're stuck with 802.11b.It's the narrowest,or slowest,broadband wireless connection that you can get at 11Mbps. The 11g can at times attain 54Mbps and 11n connections up to 300Mbps.
As technology keeps getting faster and cheaper,the more recent cards and routers are showing up at places like overstock.com for discount prices.
Don't get me wrong,what you have will work,but I don't know if you'll be satisfied with your speed.
Remember,if you go looking for replacements,make sure your system meets,or better yet exceeds the min. requirements,and that your Op. System will support the hardware.
If this helps,would you please rate my post?
Thanks
Bob
Aug 21, 2010 | Linksys BEFW11S4 802.11b Wireless...
The wireless network is very slow compared to when I connect to one of the RJ45 ports in the back of the router. Every wireless connection I try crawls in speed. I have Wireless -G USB adapter in one...
Makesure your computer is not too far away from your wireless router andyou have a good signal. By placing your mouse pointer over the wirelessconnection icon, located in the bottom right corner of your taskbar, you cancheck to see if your signal strength is good. Anything less than a good signalcan cause intermittent connections.
SOLUTION:You will need to relocate your wireless router closer to your computer.
Dec 16, 2009 | Linksys WRT160N Wireless Router
Ethernet works wirelss is very slow
Most of the wireless adapters connect at a speed of 54mbps max, while wired lan connection adaptors (LAN adapter/cable) works at max of 100/1000mbps. hence use a cable to connect the PC to make it faster than using wireless.
Aug 17, 2009 | 2wire 1800HG Router (RG1800HG00)
Chng internal wireless adapter from 11Mbps to 54 Mbps
The 802.11 protocol is for wireless adapters. If your is 11MBs, it is a b card. Buy a g or n card to achieve the 54 MBs you want. Be sure to uninstall the b card and software before you install the new card.
Good luck, and please let me know how this works out for you.
~ Spoem
Apr 02, 2009 | Dell Inspiron 8600 Notebook
Where and what (sim card only, wireless card+sim card ??) to put into an hp nc6000 laptop to have benefit of what is yet inside (or supposed to be inside like the antennas ) and access to internet ,...
A wireless card should be already be in that system. There is no SIM card. According to HP's specifications, your laptop should have one of the following wireless devices integrated into the laptop:
The HP nc6000 notebook supports a broad range of secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also an option and can be combined with any one of the supported wireless LAN options. All integrated wireless LAN options Wi-Fi certified
Cisco Compatible Extensions support
Wired Equivalent Privacy (WEP) support up to 128-bit keys
Wi-Fi Protected Access (WPA) support
802.1x standards support including EAP-TLS, Protected
EAP (PEAP) and Cisco-EAP (LEAP)
Dual antennas integrated in the display enclosure HP W500 802.11a/b/g Integrated support for 802.11a, b and g
Up to 54mbps throughput performance
Advanced Encryption Standard (AES) support Intel PRO/Wireless 2100 802.11b wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b
Up to 11mbps throughput performance Intel PRO/Wireless 2200 802.11 b/g wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b and g
Up to 11mbps throughput performance Integrated Bluetooth Designed to the Bluetooth v1.1 specification
The full information is here:
http://h18000.www1.hp.com/products/quickspecs/11794_na/11794_na.HTML
If everything is working properly, all you have to do is find your local Starbucks or other WiFi hotspot and connect.
Mar 09, 2009 | HP Compaq nc6000 Notebook
Lan wireless card
thats the 1mbps is the adsl down load speed or the transfer speed ur service provider provides u. that from exchange to router. 54 mbps is the transfer of data rate  bw ur router and computer
Jul 31, 2008 | Computers & Internet
Wireless b router
The only difference is that Wireless B is older and only hits 11Mbps. Wireless G is a step above, it is backward compatible, and supports up to 54Mbps.
If you are looking for more than that try wireless N.
May 08, 2008 | Linksys Wireless-G Broadband Router
Dell Latitude D600 Notebook Logo
77 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
