Question about Nokia N80 Cellular Phone
Nokia N80 problem
Hi :) I am despered .. my nokia is broke .. so at the beggining it wsas no such prob ... when i slide my pannel up or down a white screen showes up .. but for 3 - 4 sec. But today ... the white screen showed up and never dissapeared again i cant use my phone ... i just cant turn it on ... only white screen :( Can u please help me. Thank u
  • 7 more comments
  • kshn Feb 03, 2008
    nokia N80 totally closed. not opened. while charging it shows a white screen. no other particulars and/or data not provided. totally collapsed
    condition.
  • Anonymous Feb 20, 2008
    I hav a problem wen i slide my pannel up,the display screen becomes white and the pannel is turned down,i get the normal dispay screen.........
    with dis its very hard to dail numbers,send msgs...etc..
    plz anyone help me......
  • Anonymous Oct 30, 2008
    my n80 had a white screen problem and I don;t know what's on with the phone
    first I've a problem with cable,now i'm changed it already.If there someone know what's the problem and how 2 fix IT (".") plZ helpppp
  • Anonymous Nov 09, 2008
    SCREEN NOKIA N80 BECOME WHITE
  • Anonymous Nov 10, 2008
    My phones screen is just blank....everything still works but the screen is just blank..i think the LCD i messd up or sumthing
  • Anonymous Nov 12, 2008
    Hi..My Nokia N80 is simply white when I pull on the phone, I can't even see nothing only white...I need advise,,what could really be the problem
    Thanks
    Blackk Mann
  • youngking50 Nov 12, 2008
    whilt ok s
  • pmamwell May 02, 2009
    my phone go on but screen are blank n80
  • skyzer0x_86 May 11, 2010
    for now,my N80 still in good cond...for sure this problem will happen to me later...
    can i know where can i get all those ribbon stuff and video to guide me to clear this problem?
My problem with n80 is  next  when I open the slide the screen become like in 256 colors then i push the camera button and its come back to normal until i use  the phone when i close the slide the problem start again.What to do?
Posted on Aug 01, 2008
    Problem Solver:
  • 9 Answers
N80 white screen problem 95% chance it is a cracked ribbon cable easily replaced just a little time consuming.
if your screen comes n goes for a while before goes completly then ribbon for sure
cables avalible from ebay for instruction video just google it
if not take it to the nearest service centre.
hope this helps
Posted on Jan 31, 2008
  • 66 Answers
Well try and remove battery for 5 min and then try to switch it on ,check also in sm oder phone that ur battery is workin properly and then insert the battery and switch on!!if it doesnt work then its better u go for d repair there can sm problem with the display!!!
Posted on Jan 29, 2008
    New Friend:
Can you tell me how to put the ribbon on plzz got all the tools i need plzz i beg!!
Posted on Jan 16, 2010
Just today I replace the flex ribbon and my old device is work smoothly now.
shahriar tarafder
Posted on Nov 23, 2009
Easiest way! burn ur phone :P
Posted on Aug 04, 2008
You need to reboot your phone
Posted on Mar 24, 2008
However I m pretty sure that my LCD still in working condition and ask if it is possible for them to just replace ribbon without LCD and refuse to do that. Then as usual they charge me RM25 and said this charge will be deducted against the labour charge if I fix my phone within 3 months time.
I had went to Low Yat and most of them quoted me RM85 and above.
I had downloaded some repair manual and video guide, bought myself:
1.)Flexi Ribbon Cable - RM40
2.)T6 Screw Driver (phone screw driver) - RM10
Spent about 1 hour plus fixing on myself and now my screen back to normal, since 17th Oct till today my phone had been working like normal, quite happy with the outcome.
I need to clarify something here, my friend is using Samsung now and she does has the slide out white screen problem. I understand that slide and flip phones got higher risk than bar phone as we slide and the cable will start moving and rubbing on the board. Not really Nokia have this problem.
So I learned that phone with flip and slide might face this problem and if we face it on over-warranty unit, quote it with Nokia Care, if they had over-quoted you I guess you can have some adventure if you go for budget. Google the repair manual and Youtube the video guide.
Posted on Feb 27, 2008
Where were you able to download the manual to take apart the N80 for the slider ribbon cable - I've only managed to get that far and am now stuck :-(
Posted on Jun 09, 2008
6ya staff
SOURCE:
My phone is already white screen.nokia N80
White screen are symptoms for Contact retailer. try to call 112 (emergency call) if its working, meaning it's LCD problem. If 112 working try to clean the terminal of LCD. IF this doesn't work consider replacing it.
Sep 09, 2011 | Nokia N80 Cellular Phone
My nokia N80 when i slide slider upward the LCD become white.i cannot type a message .
Most slide up phones usually having problem with the display,particularly the flex connector which connect the upper and lower panel,can also be a LCD problem when the phone experience dropping off the ground or damage by water,just visit any mobile service shop near for a complete diagnosis and troubleshooting.
Aug 27, 2011 | Cell Phones
Unlock code for my nokia 6303
Ideal for Nokia Any BB5 Models including:
Nokia BB5 SL3 : N97, N97 mini, N900, 2220 Slide, 2700 classic, 2730 classic, 3600 slide V56.26, 3720 classic, 5130XM V59.42, 5230, 5310XM V58.58, 5630XM, 5730XM, 5800 navigation, 6202 classic, 6208 classic, 6260 slide, 6300 V57.20, 6303 classic, 6500 classic V59.45, 6500 slide V59.60, 6700 classic, 6710 navigator, 6720 classic, 6760 slide, 7230, 7310 supernova, E52, E55, N86 8MP, X3, X6
Nokia BB5+ SL2 RAP3 9DDB : 3600 slide, 5220 XpressMusic, 6600 Fold, 6600 Slide, 7210 Supernova, 7310 Supernova, 7610 Supernova, 7510a Supernova
Nokia BB5+ SL2 Rapido : 5800, 6110, 6120c, 6120N, 6121c, 6124c, 6210, 6220c, 6650, E51, E63, E66, E71, E75, N78, N81, N81, N79, N85, N82, N95_8GB, N96
Nokia BB5+ SL2 : 3120C, 3555, 3555b, 5310, 5310B, 5610, 5610D, 6263, 6300i, 6301, 6500S, 6500C, 6555, 7500, 7900, 8800 Arte
Nokia BB5 : 3109c, 3110c, 3250, 3500c, 3500cb, 5200, 5200b, 5300, 5300b, 5500, 6085, 6086, 6086b, 6125, 6126, 6133, 6131, 6136, 6151, 6233, 6234, 6280, 6300, 6300b, 6630, 6680, 6681, 6682, 7373, 7390, 8600, E50, E61, E61i, E62, E65, E90, N70, N71, N73, N75, N77, N80, N92, N90, N91, N91-8GB, N93, N95
Apr 04, 2010 | Nokia 6303 Cell Phone
My N80 bring a white screen when i slide my phone
if you phone is less than a year old take it to car phone warehoue there will sort it out for free if not it will cost around 45pound ths pls rate
Mar 30, 2009 | Nokia N80 Cellular Phone
Nokia N80 Lcd screen
its a problem with ur Glex cable its the faulty part ion this case.
Dec 20, 2008 | Nokia N80 Cellular Phone
Slide up, screen goes white but keys are active...
The strip that connects both the upper and lower slider is damaged ... replace it
Dec 11, 2008 | Nokia N80 Cellular Phone
Display problem in Nokia N80
It's a problem with the wiring that connects the upper part of the phone to its lower part when you slide it up. The wiring apparently gets damaged easily and you need to have it replaced, the wiring only, not the phone. This has also happened to me and I sent my phone to a certified Nokia Service Center. They replaced the faulty wiring but since my phone was still under warranty, they did not charge me anything. Hope your phone is still under warranty. Good luck.
Jun 13, 2008 | Nokia N80 Cellular Phone
N80 problem
I have nokia N80 and when i drag the slide i have a white screen
can some one please guide me as to how to fix this !!
Mar 17, 2008 | Lands Phones
White screen
i think ph internal phone memory is full, no space left even for bootup. For that u hv to format ur ph using *#7370# but b4 doing so plz NOTE U LL LOSE ALL UR DATA and remove memory card first.
hv fun ;)
shuweb
Mar 16, 2008 | Nokia N80 Cellular Phone
Nokia n80
Java games (.jar/.jad) and Symbian games (.sis) work on your phone (not all .sis games will work since there are many different vesions of the Symbian operating system).
Mar 11, 2008 | Nokia N80 Cellular Phone
Cell Phones Logo
3,890 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
