Question about Acer ScanPrisa 640U Flatbed Scanner
Scanning slides. When I attempt to scan slides, I get the message 'callibration failure, please check if the TPO module is firmly connected' I have tried many times but get no further. Can you help me please, Beryl
  • 3 more comments
  • bjmacp Jan 30, 2008
    I have used it a lot in the past and it still works as a normal scan.
    There does not appear to be any problems with the cables.
  • bjmacp Jan 31, 2008
    I have tried a number of times disconnecting etc but I do not think I have tried reinstalling drivers and software. Will try thanks. B.
    I have now disconnected, reconnected, reinstalling drivers and software but it is still the same. B.
    More help please. B.
    Thank you for all the help.
    I had everything as suggested however the frame was facing backwards and when turned has now worked. Thanks so much for help. I trust it will continue
    B.
  • 1,113 Answers
Ok, to be able to scan transparent slides you must have the model equiped to cope ie there will be a T in the model number 640.
You also must use a frame, this frame must not have the calibration area blocked and must be set with calibration area(smaller rectangle) facing front.
see page 10 of your user guide for more info
Posted on Jan 31, 2008
  • 4 more comments
  • Soulvisitor
    Soulvisitor Jan 31, 2008
    Oh the Acer 640U and BenQ's Scanpreista product is the same.
  • Soulvisitor
    Check your driver suits 640UT i beleive it is most likely the same as the 640U from what I know.
  • Soulvisitor
    The 640UT also has a optical cover that one must remove before using tranparent originals
  • Soulvisitor
    Soulvisitor Feb 01, 2008
    Great to hear can you please rate/accept my solution
    S.
  • Soulvisitor
    pic
  • Soulvisitor
    Soulvisitor Feb 02, 2008
    Thankyou, them stars sure look pretty :)
    Sergeant:
  • 201 Answers
Hey there bjmacp, the problem is your scanner is not suited to the task. what you need is a drum scanner or a high end flatbed scanner that will allow you to focus. Good Luck!
  • Devocap
    Devocap Jan 31, 2008
    hey there bjmacp, the reason for the need for user focus feature on the scanner is due to the extra layer of glass on a flatbed scanner. This is not a problem on slide scanners as they do not have glass between the slide and the reader. Hope it helps.
    President:
  • 1,944 Answers
Did you try the trivial stuff like disconnecting and reconnecting the unit from the PC and electricity, reinstalling drivers and software?
Posted on Jan 30, 2008
  • Damen Wong
    Damen Wong Jan 31, 2008
    Could you please tell me what program are you using with the scanner?
  • Damen Wong
    I am glad it worked out for you =)
My scanner was scanning my 35mm slides beautiful..then just started scanning them as if they were a negative..help
Well from my past experiences with those scanners it is usually caused by the memory filling up from all the images your scanning. My first suggestion is to reboot your computer to clear out the memory. If the problem persist's then I would contact Canon you may have a problem with the unit inside your scanner that does the imaging.
I hope this helps you out if it does please give me a YES that I did attempt to help you with your problem. Thank you
Apr 08, 2011 | Canon CanoScan 4400F Flatbed Scanner
Cannot connect to the internet due to virus or spyware
Download ComboFix from here: http://download.bleepingcomputer.com/sUBs/ComboFix.exe
and put it on your desktop.
Now, please make sure no other programs are running, close all other windows and pause your antivirus software until after the scanning and removal process has taken place.
Double click on the file you downloaded. Follow the onscreen prompts to start the scan. Once the scanning process has started please DO NOT click on the Combofix window or attempt to use your computer as this can cause the scanning process to stall. It may take a while to complete scanning and this is normal.
You will be disconnected from the Internet and your desktop icons/toolbars will disappear during scanning, do not worry, this is normal and it will be restored after scanning has completed.
Combofix will create a logfile and display it after your computer has rebooted. Usually located in c:\combofix.txt , please attach it to your next post. Also, please don't forget to resume your antivirus software.
Jun 02, 2009 | Computers & Internet
Epson V100 Document Mat error
Please check if the option cable connected on the back of the scanner is seated properly.
If you are using epson scan to scan from your computer, try to scan using either professional or home mode and choose the correct settings.
May 03, 2009 | Office Equipment & Supplies
HP officejet 6110 all in one scanning
LOOKS LIKE YOU HAVE A MECHANICAL PROBLEM , need to check the motor , guidance path where the bright light travels , needs to be serviced , hope this helps
May 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Scanning slides with anoscan 4200F
have you tried checking for a firmware update from the manufacturer?
Oct 13, 2007 | Canon CanoScan 4200F Flatbed Scanner
Unable to use film adaptor
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
1) In the program you are working from, begin the scanning process. If working in full auto mode, as the scan begins you will see a message that reads TO CANCEL SCANNING IN FULL AUTO MODE AND SWITCH TO MANUAL MODE, CLICK CANCEL. At this point, click CANCEL, then MANUAL MODE.
2) You will now see all Epson Twain settings displayed. If the scanner has not previewed automatically, click the full page preview button (icon of a paper with one corner folded down).
3) Ensure the settings on the right hand side of the Twain are correct. For example, the DOCUMENT SOURCE for transparencies must be either TPU: COLOR NEGATIVE FILM, TPU: MONOCHROME NEG or TPU: POSITIVE FILM.
FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes. (If you are scanning a black and white slide in true colors, choose TPU: POSITIVE FILM as the DOCUMENT SOURCE and BLACK AND WHITE PHOTO as the IMAGE TYPE.)
If the DOCUMENT SOURCE is flatbed, the scanner will not activate the backlight in the transparency unit. If the DOCUMENT SOURCE is greyed out and you cannot select a TPU option, close the twain, reseat the power/communication cable connecting flatbed to TPU, then re-open the twain and try again.
4) Ensure the other twain settings are correct for the type of scan you are doing.
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no guidelines on this; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing an AUTOMATIC THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, click the CONFIGURATION button and uncheck AUTOMATIC THUMBNAIL PREVIEW FOR FILM, then OK, and try the PREVIEW button (page with corner folded down) again.
In this mode, you will have to manually marquee or crop the slides you wish to scan. Use the left mouse button to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process (manually crop then scan) for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Aug 16, 2007 | Epson Perfection 1200 Photo Flatbed...
When scan job is sent a start failure error comes on the display
Don't worry about the clean roller message. It is just a reminder much like your scheduled maintenance light that appears in your car.
Start Failure can occur for a number of reasons. When you get a start failure message close your scanning software and reopen it. Sometimes your connection may degrade if left idle. If that doesn't work shut down the scanner and pc. Turn on the scanner and wait until it is fully initialized before turning on the PC. These steps have resolved that problem for me. Lacking a manual, I just try things. Good Luck
May 07, 2007 | Kodak Digital Science 2500D Path-Through...
Acer ScanPrisa 640U Flatbed Scanner Logo
120 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Marvin
Marvin
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
