First thing to check would be your air filters make sure not blocked as this will act as the choke if blocked and will flood the engine,
If all is well remove plug and remove as much excess fuel as possible with compressed air etc, then reassemble and see if it will fire,(With full throttle and NO CHOKE) you may have to repeat this a couple of times...
Once you get the engine to fire it may geep running if the engine was just flooded otherwise if the engine floods again then you will most likely have a problem in your carby mabie a piece of rubbish under the needle valve holding it open causing the engine to flood and the carby will have to be cleaned and tank flushed
Good luck with it hope this helps!!!!
Kind regards
Brad
