Question about Lexmark X1240 All-In-One InkJet Printer
Lexmark x1270 when i go to print my ink cartarge slams agains the side there is nothing in the way and a small piece fell off it has L-01 on it if anyone can help please do it now thanks very much when i press print the fuckin cartridge slams to the side whats up with that?
  • Lexmark Master
  • 1,113 Answers
Re: lexmark x1270
It's losing knowledge of where the carriage is on the rail, hence the carriage tring to escape threw the side
and I'm concerned with your L-01 piece is one of these?
If so thats the cover switch but to my knowledge doesn't create the slam, that usally known to be a plasic strip that runs the width of printer, not intact, Dirty or not running threw the carriage sensor
Tell me more and I'll continue.
Posted on Jan 29, 2008
0 characters
3 Points
Do my pages print out blank
It could be that your cartridge nozzles need some cleaning. Long period of non-usage can lead to drying of ink and clogging in the cartridge nozzles. To clean the cartridge nozzles using the Lexmark software on your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Then try to print your document again to verify that the cartridges are functioning now.
Nov 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Long thin plastic piece fell out of Lexmark Z33
Google your printer, try This item goes from one side of your printer to the other, passing through the cartridges holder. Look for the places it attaches. You may have to move the cartridge holder to the center to install the plastic.
May 01, 2009 | Lexmark JetPrinter Color Z33 InkJet
Cant put printer piece back in
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
Please Note: Fixing the encoder strip is a delicate procedure.
Try to print any document.
If this failed then printer cannot be repaired, if the printer is under warranty then Lexmark will replace the printer else. I am sorry to say you need to purchase a new printer
your's tech expert
Mar 28, 2009 | Lexmark X1270 All-In-One InkJet Printer
Part FELL off!
It sounds like this is the is the position indicator tape. There should be a small hole on both ends of it that fits over a small plastic tab on eich side of the printer. It normally needs to fit in a small **** on the back side of the print carriage.
With the printer turned off & preferably unplugged, gently slide the print carriage to the center of its range of motion. Ensure that this plastic strip is still attached on the opposite end and it feeds through the back of the print carriage. There should be a small tab to attach the free end to similar to what you see on the other end. The strip should be taut but not tight enough to stretch and it should not sag. Exactly where the attach vary somewhat depending on make and model, but they are all similar.
Mar 22, 2009 | Lexmark JetPrinter Z515 InkJet Printer
Lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 27, 2009 | Lexmark X1270 All-In-One InkJet Printer
When i try to print something on my x5320 all in one printer, the ink carrier slams into the the right side of the printer . on the liquid crystal screen it says " clkear ink carrier jam" ...
contact lexmark sounds like a major fault is it still under warranty ??? I dont think a virus would explain your printers strange problem.
Aug 01, 2008 | Lexmark Printers & Copiers
Printing and coping problem has some of those options
Jul 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
582 people viewed this question
Top Lexmark Printers & Copiers Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Printer and Copier Expert? Answer questions, earn points and help others
