Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
1 gb usb
I have delete the partition of my 1 gb usb when i connect it to my computer the (H) derive which is the usb derive shows no disk in derive when i check it properties it shows usb volume(0) free space (0) tell me what to do
  • hell boy Jan 31, 2008
    no i tryed it but vain
    acatually the (h) derive which is the usb derive when i connect it to my computer shows no disk in derive when i format it
  • 167 Answers
Hi
You need a format your USB drive!!!
Plug in USB drive and in MY COMPUTER right click on the USB drive!!! Select format and that will do it!!!
Good luck!!
Posted on Jan 29, 2008
Please i need help i recently used windows XP disk administrator to delete some partitions of my Quantum Fireball Lct15 500GB and now it only shows 13GB avaivable, what could i do to recover the original...
use disk admin again and delete the 13 gb partition... reboot.... get back into disk admin and check the drive. you will have to create a new partition and format it before you can use it
Mar 13, 2011 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
Hello everyone, i have a problem with my Verbatim smartdisk. Before I formate it, it was in Fat, had 2 partitions and 250 Gigabyte. After formatting, there is only one partition in NTFS and has only now...
Click Start
RIGHT-click "My Computer".
Click Manage.
Click Storage.
Click Disk Management.
Click to delete one partition on the disk-drive.
Click to delete the other partition on the disk-drive.
Click to create one partition on the disk-drive.
Format the partition.
Done.
Dec 27, 2010 | Verbatim SmartDisk Firelite Portable USB...
I made partition in my Kingston 4 GB USB and one of the partition is not opening. I want to delete partitions to get my 4 GB capacity back.
Probably best to copy all files off and reformat it.
It would have made more sense to use folders and not partitions.
You may not be able delete the partition if you cant open it.
Does it show up in disk manager?
Jul 22, 2010 | Kingston 4GB Secure Digital High Capacity...
My transcend 1 gb pendrive shows only 250 mb capacity without having copied any content..
right click ny computer click manage than go to disk management and click you ubs and delete the partition of you usb and repartition it. waring do not do any than to local disk (C:) in the partition
Apr 11, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Can not format my samsung hard drive with DOS command and Disk Genius and lost 49 GB capacity. What can I do?
You may have the hard drive partitioned into two or more partitions.
Delete all the partitions and create a single partition and then format this single partition on the hard drive.
Mar 14, 2010 | Samsung (SP0822N) 80 GB Hard Drive
USB 16 GB transcend says disc is write protected!!
You should try to delete the partition in the Transcend memory stick and creat a new partition. You should copy any files that you need off this memory device before you re-partition it because you will lose all the data that is stored on the device.
Go to the Control Panel - Administrative Tools - Computer Management - Disk Magament.
Scroll down until you see your removeable device the 16Gb memory device, click once on this, It may not show it as Healthy.
Right click in this disk (make sure you do not select the C drive) and click on Delete Partition to remove the partition.
Right click on this unpartition drive and Create a partition.
You may not have to format this partition, it should now show this as a healthy drive.
Exit out of Disk/computer Management and Control Panel.
The USB drive should now function normally.
Mar 04, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
See only one of four partitiona in a mobile disk
Go into the control panel.
Go to administrtive tools.
Go to Computer management.
Click on disk management on the left side of the screen.
Click on the drive you partitioned.
Does it show four partions?
Were they partitioned as NTFS or a different format?
Jul 16, 2008 | Samsung (MP0804H) 80 GB Hard Drive
About 1 gb usb
hey i had this issue too....
but myne was a little different on a 64MB card it showed 33GB but it was a virus..!!
what i did was i plugged it on a mac and formatted it and came back to life a a new drive !!
I think this helped !! if no mac then try the dos !!
eg:
like this : Your Driver Letter=G:
take run type cmd
in the dos window type " Format G: /X /FS:fat32
then type the current name of the volume(NAME or try Removable Disc)
and press ENTER
after the format type EXIT
and there u have ur drive back !!
Jan 09, 2008 | Kingston (SDCZ2-512-A10-KT)...
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
186 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
