Question about Dell OptiPlex GX260 PC Desktop
Power buton permanently on but system won't start
I was trying another hard disk on my pc recently. In the process I connected the hard disk to the cdrom drive's cable or to the main's hard drive's cable. When I thought I was done, I put my original hard disk back in place as well as the connecting the cdrom. When I restarted the pc, the power button came on as usual to sort of identify the hardware in place and went off. After a few seconds it came on again and the system doesn't start. What could the problem be and what should I do?
Thank you in anticipation.
Harry
  • nkomeharry Jan 30, 2008
    The problem was solved. My PC is working well once again. Thank you for your assistance.
    Harry
    Genius:
  • 1,226 Answers
Ther original haddisk is primary master, and should the 2nd must be primary slave. If you connect the 2nd hard drive where cd rom place , you get the jumper to make it slave. see jumper setting on hard disk label.
and try to remove the memory and fix it back the, if the system is no power it all, the PSU is damage, but it is not then try fixed some connection related to your system.
pls leave a comment b 4 u rate, Thanks!
Posted on Jan 29, 2008
    Genius:
  • 1,067 Answers
Cheak cables again take batery out back in reset bios make sure middel of cable is slave end of cable jumpers on cd rom hd setto master ok
  • nick helpap
    nick helpap Jan 30, 2008
    rayte me as fix ya too same effect 1st responce thx nick
How do I get my lap top to work
That page is the BIOS "basic input output system" it looks for an operating system usually on a hard disk. Either your hard disk has crashed or there is a problem with the motherBoard and the hard disk controller. You can try removing the hard disk and putting back in as it could be minor corrosion where it plugs in.
Jan 10, 2013 | Computers & Internet
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
Lookbook will not power on
A computer that won't start can be both alarming and infuriating, especially if you're on a deadline or you haven't been backing up all your data (like we all tend to do). Don't panic, though-this problem often has a simple solution.
1.If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
2.If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
3.If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
4.If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
5.If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
6.If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
7.If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it. (See also How to Fix Bad Sectors on a Hard Disk and How to Recover Lost Files.)
Aug 26, 2011 | Computers & Internet
My desktop computer won't turn on it just keeps blinking orange.
1. If your desktop computer does nothing at all when you try to start it, first check that the power cable is securely plugged in at the back of the computer as well as into a working power outlet. It's amazing how often this is the case.
2. If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
3. If the computer is plugged into a surge protector, see if the surge protector has a reset switch that you can push. (If it doesn't have a reset switch and the problem is with the surge protector, it will need to be replaced.) Try plugging a lamp or other device into one of the surge protector's outlets to make sure it's working.
4. If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
5. If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
6. If the operating system still won't start even though the computer and monitor have power, try restarting with a Windows CD-ROM in the CD-ROM drive or, if you've got a Macintosh, with a Mac OS disc in the CD-ROM drive. (You can start a Mac from the CDROM drive by holding down the C key while starting up.)
7. If the operating system then starts, your problem is probably with the startup hard drive or with the operating system installed on it. If you can't fix the drive, you'll have to replace it.
You can check it here as well:
The minute your computer's hard disk starts to act flaky, make sure you have an up-to-date backup. Then you can do some simple diagnostics and repairs. Both Windows and Mac OS come with built-in hard-disk utility software that scans your hard disk for errors and attempts to fix them.
1. Double-click on My Computer to open the My Computer window.
2. Select the disk that you want to diagnose and repair.
3. Choose Properties from the File menu. You should see the Properties window for the drive that you selected.
4. Choose the Tools tab.
5. Click the Check Now button under Error Checking Status.
6. Depending on your version of Windows, choose either "Thorough" or "Scan for and Attempt Recovery of Bad Sectors."
7. Click on Start.
Aug 17, 2011 | Computers & Internet
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
I'm looking for recovery disks for a gateway MX6450 my hard drive crashed.
The system recovery process for your computer is stored on your hard drive. As long as you are trying to reload your hard drive, not replacing it then you can access and run the recovery application without going into windows.
The access the system recovery without going in to window:
Power your computer off.
Disconnect all external devices including printers and pc-cards (external mouse and keyboard can be attached)
Power you system on and watch very carefully for a message that says 'Press F11 to start system recovery'
Press F11 as soon as you see this message.
From her you can go through the recovery process.
Nov 14, 2009 | Gateway Computers & Internet
When i turn the pc on it goes to hit f1 to cont of f2 and then it says it can not read the hard drive
First open cpu cabinet.
Then reattach both connection cable power cable and sata or ide cable to harddrive.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios then check there your harddisk is detected?
If your harddisk is detected in bios you can boot your harddrive.
Let me know if you need more assistance.
Thanks.
Oct 06, 2009 | Dell Dimension 3000® Pentium® 4...
Operating system
Most probable cause is that the pc is unable to detect the Hard Drive, could be caused by some loose connections/wirings. Open the CPU case and try to re-attach the cables from the motherboard to the hard disk drive, and try your pc again.
Jun 03, 2008 | HP Computers & Internet
My hard disk
Hi, A few questions first.
Have you recently changed any hardware in your PC?
Have you recently had any power outs or surges?
Have you at all changed any settings in your system setup?
What type of hard drive is it?
What operating system are you using?
Please let me know
Nov 21, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
Acer 1690
They may be correct, although you can try pressing F8 on boot up and and enter safe mode. When in the menu choose 'Last Known Good configuration' and press enter, allow a reboot and hopefully you get into windows. It may also be the boot.ini which is damaged at tells the harddrive where windows is, but you will need your Windows disc to repair the system.
Apr 09, 2007 | Acer Notebook
Dell OptiPlex GX260 PC Desktop Logo
76 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
