Yes there is just follow the following:
To setup your Belkin Router please follow the steps below.
Once the router is connected, check if your PC is communicating with the router. On the desktop click on
Start and then on
Run. In the open box, type
cmd.
It will bring up the command prompt window.
Type the command
ipconfig in that window and press the
Enter / Return key on the keyboard. It will bring up results similar to the image below
Note the values of
IP Address and
Default Gateway in the
ipconfig command results. If the IP address is in the range of
169. 254.x.x or
0.0.0.0, then the PC is not communicating with the router. In this case contact your router vendor for support.
If the IP Address is in the range of
192.168.x.x then the network setup should be ok.
Note the values of IP Address and Default Gateway. Close the command prompt window. The default gate way for belkin is 192.168.2.1
Open
Internet Explorer window and in the address bar type in the address that you found for Default Gateway. In case of Belkin router it should be 192.168.2.1. Then click on the
Go button.
It should bring up a screen similar to the image below. Refer the product manual for the default Router password. In case of most Belkin routers, it is blank. So, just click on the
Login button.
This should bring up the
Belkin Router Setup Utility. Click on the
Wizard link on the top bar of this page. In the
Connection type options, select
PPPoA. Then click on
Next button to continue. Notice that on the top right side of the page, it says "
No Connection". Once the setup wizard is complete, it should change to "
Connected"
In the next window that appears, enter the broadband email address and password in the respective boxes. Then confirm the password in the
Retype Password box. In case of
VPI/VCI:, type
0 and
38 in the left and the right boxes respectively. Then click on
Next to continue.
Click on the
Apply button to save the settings.
It may take up to 5 minutes to save and update the settings. Once completed, you will see, "
Connected" on the top right side of the window. Once you see that close this window and open your browser window to go to any website.
Hi, Please provide the operating system in your laptop,is it Windows XP,Vista,Windows 7 or MAC Since if its XP then it doesn't support WPA password. Check and confirm and send a reply Regards, Ayyasam
