Link
Receiving a fax
You can choose to receive a fax automatically, manually, or through an answering machine.
Note: For your All-In-One to receive a color fax, the machine from which you are receiving must also support color faxes.
Automatically
Recommended for a dedicated fax line
Your All-In-One automatically accepts incoming faxes using the
automatic answering mode. When the Auto Answer light is on, the
All-In-One receives a fax after the specified number of rings set in
the Options menu.
To set a number of rings for the automatic answering mode:
- On the control panel, press Mode repeatedly until Fax is selected.
- Press Options until ANSWER FAX WHEN appears.
- Press + to choose After 1 ring, After 2 rings, After 3 rings (default), or After 5 rings.
- Press Select.
- Make sure the Auto Answer light on the All-In-One is on.
When the number of rings that you set is detected, the All-In-One automatically receives your fax.
Manually
Recommended for a shared fax and telephone line
You can choose which incoming faxes to accept by setting your All-In-One to manual answering mode.
- Make sure the All-In-One Auto Answer light is off.
- Press *9* on the telephone after you answer the telephone and hear fax tones.
- Hang up the telephone.
The All-In-One receives your fax.
Answering machine
To receive a fax with an answering machine
connected to your All-In-One, set the answering machine to answer
incoming calls before the All-In-One does. For example, if you set the
answering machine to answer calls after 3 rings, set the All-In-One to
answer calls after 5 rings.
- Press + until After 5 rings appears.
- Press Select.
When a ring is detected, the answering machine picks up the call.
- If a fax is detected, the All-In-One receives the fax and disconnects the answering machine.
- If not, the answering machine completes the call.
Note: You must set up the equipment as shown in connecting to an answering machine.
