Question about GE Spacemaker JVM1640SJ Microwave Oven
No power so the thing just quit... no power whatsoever. checked the outlet it is good. took buttons off to see if i could find a fuse.. no such luck... thoughts?
  • BayDoula Jan 31, 2008
    Same thing happened to me yesterday. I'll let you know if replacing the fuse helped.
  • dgoth Feb 15, 2008
    Same exact problem here too. Microwave is only 18 months old. Damn 12 month warranty! Worked fine last night, today no power at all. Outlet is fine. Any way to check get access to the internal fuses without removing from under the cabinet?
    Thanks!
  • 2,130 Answers
You mentioned taking the "buttons" off. That may not give you complete access to the units motherboard or power supply area. Unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Posted on Jan 29, 2008
Our Maytag 2001 microwave white over the stove just quit. Is it dead?
there is a fuse in the cabinet for the electronics but you will need an electrician to get to it. have it check ed out or junk it.
Nov 18, 2014 | Microwave Ovens
No power - not the outlet or a fuse
If the internal fuse in the microwave is good, then it could be a bad wiring connection somewhere in the oven, or a thermal cutout has failed.
Jun 26, 2014 | Samsung SMH9187 Microwave Oven
No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Jul 16, 2012 | Microwave Ovens
No power to oven; checked power to outlet and I do have power; looked for reset button but did not find one
If it is completely dead, check the main fuse, which is likely a AGC ceramic type. If dead, you can buy from Electronix: http://www.electronix.com/ and click microwave in the left column. Good luck with it.
Apr 19, 2011 | Magic Chef MCD1311ST Microwave Oven
I have Whirlpool Microwave oven Model MH6110XEB-0 that has completely loss power. The outlet it is plug itno is still good with power running thru the outlet. I do not have any manuals for the microwave,...
with any luck you have just poped the inline fuse,
if you remove the control board you should be able to see the tube fuse up by the fan motor
if not the whole thing will have to come down to reach it
Oct 14, 2009 | Whirlpool MH3185XP Microwave Oven
Just quit. No power, no display....nothing
there are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
Sep 10, 2009 | Samsung MS1040BB Microwave Oven
No power
there should be a 20amp fuse that probably blew
Jan 01, 2009 | Sharp R-320B Microwave Oven
Microwave oven
Check the wall AC outlet by using a meter or another electrical appliance such as a table lamp. If no power there replace the fuse or reset the circuit breaker.
Does your microwave light up when you open the door?
If not, it could be a bad power cord, on/off switch AC cord or fuse.
Check these first.
If you cannot solve the problem, you'll probably need service.
Hope this helped.
Mar 25, 2008 | Panasonic NN-P794SF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
133 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
