Question about Jensen XA2150 Car Audio Amplifier
Sound comes on, goes away
It is definately NOT temp related. I have to get this amp fixed because I bought it 7 years ago and its molded into a seat to fit. I sent it away to Protech and they said nothing was wrong with it. I will be driving and all of a sudden the sound will go away, usually fades off first. If I turn it up high it shuts off pretty much. I have remote switches on my dash and if I turn them off then back on sometimes htey kick back on. Im not sure what to do but I HAVE to get this working again. They have been where they are for 5 years and have never had one problem with them. Other amp works fine. The amp not working is a Jensen 300 watt amp 2 channel and I use it for subs. Any help is appreciated.
  • 113 Answers
It needs to be checked for faulty solders if you dont know how to do this take it to a tech
Posted on Sep 08, 2008
Started tripping circuit breaker. It's on a 15 amp circuit, we bought it two years ago and it only started doing this last week. It first did this 7 minutes into cooking a frozen meal. Then four minutes, 3...
The problem could be a failing magnetron or control board. The tingle may be traceable to a faulty receptacle installation - one with a floating ground or incorrect wiring such as reversal of the hot and neutral lines. The vibrating sound seems to be one of the quirks of GE microwaves.
Apr 28, 2017 | GE JES1358 Microwave Oven
My 2003 Mercury Mountaineer has an electrical problem. It started about a year ago with the key fob not working, I have bought 3 and all won't work even after re-programing. now tonight I went to
Could be a windshile leak down the A-Pillar & water
gets into the delayed accy relay for the GEM Module
(Body Computer as ford called it for a few years) & you
get what you have now
Try Goolge as I did a few weeks ago for a relative
He had the same issue with the blower being on &
killing the battery
No real fix I found for the windshield leak
Seem a robot didn't put the rubber sealant
on correctly at the factory fo about 5 years
on several fords.
If it isn't water related then the GEM Module
controls all those body features
If you get a used one & match up the numbers,
you supposedly can avoid buying a reman gem
& the expense of having to reflash it to your factory
built combination
Jan 27, 2013 | 2003 Mercury Mountaineer
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
5 yr old tv goes through cycle and tries to come on, eventually does but after many tries.
My sony did almost the exact same thing. I removed the bulb & cleaned all the dust out of the cooling ducts & the screen on the bulb was full of dust. That bought me about a month, then I replaced the bulb & haven't had a problem since(over a year ago). Just make sure you NEVER touch the glass of the new bulb with your hands,oil on your skin will greatly shorten the bulb life! I found a bulb at a local electronics store for under $200.00... don"t forget to clean dust from cooling ducts,& make sure cooling fan is working, bulb gets extremely hot!
Mar 02, 2012 | Televison & Video
I have a sony ta-fe370 amplifier. I bought it 5 years ago. 4 years ago it stopped working. I would now like to repair it. The problem is that it turns on and the power light comes on and so does the...
The problem is hard to track down, but fixable. You need to determine if the pre-amp has failed or the power amp. To determine which try this: Connect a device which plays music and turn the volume control fully up! You can sometimes hear the sound better via a pair of headphones. If you can hear any signal or music breaking through, then the pre-amp section is OK. If you can't it might not be. If you can hear faint music then it will be the main power amp to blame. Now because you have lost both channels you must only investigate devices (such as IC's) which have both channels running to them. Some amps have one big power amp IC that does the work. So if that goes it takes the sound with it. Have a look at whatever is on the big heat sink first, that will determine a lot of your future actions.
Jul 06, 2011 | Sony TA-FE370 2-Channel Amplifier
Humming sound in subwoofer after it's been playing for a while
It sounds like you are describing an earth loop problem. I won't go into detail in this post, but try an isolation test first. disconnect everything from the reciever except the sub and try connecting say a BATTERY powered mp3 player or cd player to minimise connections to the electrical mains earth. you could also isolate things by taking your sub to a friend's house and trying it on their system.
If it is an earth loop use a process of elimination to find out which two pieces of equipment causes the earth loop. then apply filtering.
you can buy earth loop isolation transformers for about AU$26 and I've used one on my sub myself. Theyhave RCA (phono)plugs on each end and they connect inline with the signal cable to the sub amp.
as for the thumping sound it might be the speaker protection circuitry cutting off the amp to protect the subwoofer speaker from damaged. This might be triggered if the earth loop sound is causing the sub amp to overload and clip.
Failing this there might be a dried out overheated electro capacitor in the amp circuit causing the hum. Hav a chat to your local electronics person, who should be able to spot it!
Hope this puts you on the right track
Happy Hunting!
Jan 07, 2010 | Sunfire Audio Players & Recorders
Color gets hazy & basically is only pink & green
try to open the unit.then check for anything suspicious, like connectors if properly connected etc.then , power it on.look for something that causes the fan to stop running or anything related to that.check the lamp, too.
May 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Noise when car is started
Sounds like the starter stays "sticked"on... Check the starter relay or after the sound goes away touch the starter for heat. If its too hot it means it stays on working even when the engine is allready running...
Sep 30, 2008 | 1998 Volkswagen Beetle
Phillips 42pf9630a 42 in
A code 7 is related to a hardware problem that reqiures service.
If you want to get a referal to a Philips authorized service center call 888-744-5477 and they can prive contact info for a servicer in your area.
Aug 21, 2008 | Philips 42PF9630A 42 in. Plasma Television
Jensen XA2150 Car Audio Amplifier Logo
70 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
