Question about RCA F35731MB 35" TV
The picture no longer fits the screen.
I had problems the first couple of years with the picture outsizing the screen. A Sears repairman came in and swapped out a board saying it at to do with the the pins. Is there parts still out there to fix or am I S.O.L.
If you know the part number there is a site, PartStore.com, that sells quite a few parts for it.
Posted on Mar 26, 2008
  • wizdude4444 Mar 26, 2008
    I have the same problem, only I got mine used in the same condition. if you do know the part number, I would be extremely grateful if anybody could let me know.
Plasma color TV screen developed dense black vertical line
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Sep 21, 2009 | Hitachi SSH2442 Television
We are very discouraged with out kenmore appliances. They didn't seem to last as long as we'd like. Our refrigerator is only 8 years old and it's had problems from the beginning. We are now replacing a...
Hello. I do not work for Sears but I do work on lots of appliances. Do not put 500 into a computer board.
All appliances these days are designed to last about 7 years. If yours last longer, consider yourself lucky.
The good news is a new fridge and a new freezer will use much less electricity and will save you money within a couple of years.
Jul 07, 2009 | Refrigerators
Have to push power repeatedly to get TV to turn on, b&w picture
the CRT is obviously very old and discontinued ,I would recomend investing in a new set
Jun 11, 2009 | Televison & Video
Flickering picture and color smear
Trash it Toshiba T.V. and laptops have a flickering problem with is caused by a failty power supply
May 27, 2009 | Toshiba 52HM95 52" HDTV Projection...
Picture is shaped like an hour glassmodel no ht 2751a
talked to repairman will cost more to fix by a sears repairman than worth saw answer to what it was on your site thx might try to talk to another repairman before abandoning
May 12, 2009 | Recoton Advent Advent HT3251A TV
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have sound but no picture!
Usually a loss of picture problem on this set is caused by parts on the circuit board failing. Most often a repairman will find the problem around regulator in power supply or around main output transistor in horizontal circuit. Either way, solder work and test equip. are required.
May 19, 2008 | Proscan PS60690 60" Rear Projection...
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Unavailable Part
More properly called the "A" or main board.Can be repaired by
a qualified tech in a shop setting.Possible horiz or power circuit
problem.
Oct 15, 2007 | Sony KV-27V42 27" TV
Televison & Video Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
