Question about RCA P61310 TV
No Sound I cant seem to get the sound to come from the tv . Tried the switch on the back internal/external, the setting from stereo to mono ect... Any one know what it may be?
    New Friend:
  • 51 Answers
Maybe a vacant channel or input is tuned.
• If watching VCR (connected only through antenna input), make sure TV is tuned to channel 3 or 4 – same as CH3/4
switch on VCR. Also check to make sure the TV/VCR button on the VCR is in the correct “mode.”
• Simultaneously press the POWER and CHANNEL DOWN buttons on the front panel to reset the TV.
HOPE THIS WILL HELP YOU.. GOODLUCK
Posted on Jan 29, 2008
No stereo sound
first this needs to know if set has internal left and right speakers
Aug 31, 2012 | byD sign Televison & Video
Sound very poor
there could be a few issues. It could be the speakers themselves. I believe this tv has an audio out. I would hook it up to a stereo and see if it that improves it. It could also be something internal like the amplifier. You have a couple options but I would just use a stereo for sound. If you still need more assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Oct 18, 2008 | Philips 42MF130A 42 in. Plasma EDTV
I've been having this audio issue with my LG 19LG30 for awhile now. Only recently discovering what exactly was going on. My audio would go in and out on some channels. There would be sound then muted for a...
to eliminate the problem just select the mono sound disable the stereo signal.so that your tv sound will be stable.this happens because not all tv stations are broadcasting on stereo signal thats why your tv keep on switching to mono and stereo base on what signal it receives.plus the signal being feed by the cable provider sometimes they are not stable enough to give the stereo signal so better select only the mono sound...tnx hope i helped you..
please rate my help!
Jun 05, 2010 | LG 19LG30 19 in. LCD HDTV
No sound on channels that have SAP instead of Stereo
You can access the menus using the buttons on the set. Go to audio menu, you'll find a setting that says listen to and have choices of mono stereo or sap, choose stereo.
Oct 08, 2009 | Mitsubishi Televison & Video
52 inch (Model D52W19) RCA TV's sound doesnt work
internal / external selector switch on back of tv near inputs or setting in menu under settings or sound labeled - internal amplifier/ external amplifier.
Sep 28, 2009 | RCA D52W19 52" Rear Projection Television
Insignia NS-LCD37 TV - no sound
Start checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Insignia NS-LCD37 37 in. LCD TV
Mono sound only
I have an LC42D64U with firmware U0709111. This is an 11 month old unit. It was working fine until I lost power one day, then I couldn't get any sound. It always showed up as Audio: mono. I tried every setting and nothing (although XBOX via HDMI still played though the onboard audio, so I knew it wasn't a HW issue).
After searching around for a method to change the mono/stereo I resorted to the Fred Flintstone's fix and simply pulled the plug on it. Immediately after turning it back on it worked.
This is hardly a fix but it worked for me.
Nov 20, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
42" Sharp Aquous audio; Mono vs. Stereo
no. that is not true. the person you spoke to obviously didn't know what they were talking about. you mean to tell me that everyone that has a cable or satellite box with a stereo or hd tv is not going to receive stereo sound? really,think about it. you only need a cable box( for now ) if you have premium channels (hbo,showtime etc). you can connect the cable line right into the tv if you only have basic cable. look at the back of your cable box. if you have a red, white, & yellow audio/video output, then the box is stereo.connect these outputs to your tv. this connection however is not hd.you will need a hd box with a hdmi cable for hd .To put the tv on stereo mode, there should be a way via the menu and/or the audio button on the remote to get it off mono and put it on stereo. your manual should at least show you around the settings of your tv.
wg
Apr 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
42PFL5532D/05
Audio from an external input only shows as mono on the TV information display.
If you are only getting sound through one speaker of the TV, check the scart connections are all in fully, and straight.
If you are getting sound through both speakers, then the sound is stereo. Stereo only shows when there is a NICAM stereo sound source, which is only through analogue terrestrial TV.
Dec 01, 2007 | Philips 42PFL5332D 42 in. LCD Television
RCA P61310 TV Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
