Question about Samsung SCX-4216F All-In-One Laser Printer
When I fax docs, it is received with stripes and stains
Please help me solve this problem, when I fax docs people receive it striped, with stains and illegible, what can I do abou it?
  • Paul64 Feb 18, 2008
    the mirros inside get dusty, I have cleaned twise and workt but last time I damageg a mirror like alumminum stick line and now is bad on thise two spots.
Thanks for getting back to me, but It prints ok, when I make copies they come ok as well, the only problem is when I send a fax, it is received striped, stained and illegible. Please help me someone to fix this, thank you!
Posted on Jan 29, 2008
Hello, thanks for trying to help me but that is not the problem, when printing it comes ok, when making copies it comes ok as well, the only problem is when I fax docs, they are received striped, stained and illegible, please someone help me!!! Many thanks!.
  • 55 Answers
First check the printer by copying something,here u can see the problem that u r telling me,or check it by scanning something in ur computer,if u can see that problem,all u have to do is,open the top glass cover, under the top cover thers a scanning unit(lamp unit),in that scanning unit ther are some mirrors clean that mirrors with cotton bud,clean the top glass,n fix everything again,problem will be solved
thnx N
  • NITIN  BABBAR
    NITIN BABBAR Jan 29, 2008
    can u show me a copy of that stained or striped document that u r telling,it will help me to solve it fast
    thnx N
Kenwood Kdc-bt945u "Wiring Diagram
OK.. black is ground...red is ignition...yellow is battery or memory...blue or blue with white stripe is amp turn on (remote)...orange is illumination (if its got 1)....white and white w/stripe and grey grey w/blk stripe is front spks and purple and green are rear spks...please give feedback if I helped
Sep 29, 2016 | Kenwood Car Audio & Video
White stripe when send fax
If the person you send to receives a copy with a missing column of text or image, chances are the scanner is failing. The scanner has a row of optical sensors. If a few of those sensors [often in a group right together] stop working, then no image is recorded from the original under the bad sensors. Depending on what you paid for the fax machine, it may well be more cost-effective to buy a new fax machine than to pay for someone to replace the scanner. To test the scanner, run the machine in copy mode and see if your copy comes out with a white stripe.
Oct 13, 2013 | Sharp Office Equipment & Supplies
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
I have received a fax and it has to vertical lines down the front of it.
The problem is with the SENDER's fax machine ... not yours...
Your fax machine is working properly...
Note that all faxes from that source will have the stripes, all other faxes that you receive from other sources will not have the lines...
You might send the fax with the lines back to the sender to advise them...
Hope this helps!
Sep 09, 2009 | HP Office Equipment & Supplies
Every Fax we send has stripes going down it making it hard for the receiver to read our faxes. It doesn't happen when we receive fax, print or make copies.
You say it makes copies without the stripes. Do you use the automatic document feeder (ADF) when you make copies, or open the top and lay the paper on the platen? If you get stripes when using the ADF, the ADF scanner area needs to be cleaned. It's the smaller glass area to the left of the main platen glass. Use a damp cloth and remove any dirt or debris.
Jun 15, 2009 | Canon PIXMA MX310 All-In-One Printer
HP 5030 do not send fax properly
Open the document feeder and clean the scanner glass.
Dec 30, 2008 | HP Officejet 5610 All-In-One InkJet...
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
Wire diagram
www.pioneerusa.com
red-12 volt ignition
yellow -12 volt regardless of ignition switch position
white-left front speaker +
white /black stripe speaker -
gray- right front spe +
gray/stripe right spe -
green-left rear spe +
green/stripe left rear spe -
purple- right rear +
purple/stripe right rear -
if this helps you please give a good rating- thank you
Aug 09, 2008 | Pioneer DEH-1600 CD Player
Blank vertical stripes on incoming faxes
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Feb 25, 2008 | Brother IntelliFAX 2800 Laser Fax
Just bought a secondhand Kenwood KDC-3024 for my boat
White and white Stripe = Front Left
Gray And Gray Stripe = Front Right
Purple and Purple Stripe = Right Rear
Green and Green Stripe = Left Rear
Feb 18, 2008 | Kenwood KDC-3024 CD Player
Samsung SCX-4216F All-In-One Laser Printer Logo
144 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
