Question about Toshiba Satellite 5005-S504 Notebook
NTLDR missing .
Hi i have a Toshiba satellite s5000 series laptop with windows xp Home edition installed. Yesterday after updating my NVDIA graphics driver my system failed to start, showing messages NTLDR is missing press Ctrl Alt Del to restart and it stays the same, please help
  • 778 Answers
Re: NTLDR missing .
You can try a system restore, and restore it to a date before you updated the drivers, that has a good chance of fixing your problem.
I am not a fan of system restore, but after reading your post I feel that it has a good chance of success in your situation. I do have some other ideas but think trying the restore first makes sense to me right now, and if it doesn't solve your problem, it's reversable.
I will watch your case and if the above doesn't work will post another suggestion.
I hope this helps you,
Posted on Jan 29, 2008
  • 131 Answers
Re: NTLDR missing .
Put the WindowsXP CD in the cd drive,
Configure your BIOS to boot from WindowsCD
After booting one the first screen select "R" which stand for repairing the installation in recovery mode
then select the windows installation you want to repair by typing the number inbetween the square brackets
you will be asked for the administrator password, type it,
once you are in recovery mode.
type this command "copy x:\i386\ntldr y:\ntldr"
where 'x' is your cd Drive letter and 'y' is your windows directory C: usually
after the message "1 file copied"
exit the recovery mode by typing exit.
restart your system.
POST back with your results
0 characters
3 Points
I have the same problem the toshiba recovery disk i get error message 10f8060017.its a toshiba A105-2194 win xp media edition. i have tried everything wiped the disk to all 0's. Used a win xp original disc...
You have tried all possible solutions and troubleshooting.
My Suggestion is to check the Warranty of the Hard Disk and get it replaced. this possible shows a mismatch between the Laptop and hard drive.
Feb 15, 2011 | Toshiba Satellite A105 Notebook
Toshiba L350 203 PSLD8E running XP Home Edition
Find out what graphics card you have. Go to the manufacturer website of the graphics card and download the latest XP driver.
Apr 17, 2009 | Toshiba Satellite Pro L350-S1001X Notebook
My Laptop is Toshiba Satellite A350 series , PATX66HLPBL , PSALWN-00C007 , 39211709K Operating System is Window Vista Home Premium . Now I want to change Operating System Window XP , How to change ? Where...
If you have a Toshiba Recovery CD you may be able to install XP, otherwise :-
You need a Windows XP installation CD together with the installation Product code.
To install Windows XP insert the CD in the laptop and boot up with the CD and follow the screen instructions.
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
Apr 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
Video Controller (VGA Compatible)... Missing
You will need to go to the Toshiba WEB site, to the support/download page, search for the video driver for Windows XP for your model laptop and install it on your laptop. There may be several version, download the latest.
Dec 09, 2008 | Toshiba Satellite A105 Notebook
My Satellite A40/A45 Series won't boot up.
If NTLDR is missing, you will need to do one of two things:
1) follow this link and follow instructions to create a NTLDR boot disc and get back up and running
2) boot to Windows CD and repair Windows installation
Hope this helps - remember to rate :)
Sep 25, 2008 | Toshiba P000392200 - Satellite A40, A45...
What is NTLDR
NTLDR is short for New Technology Loader, an essential initializing program for Windows.NT4/2k/XP.
A missing NTLDR indicates several fault possibilities, most common are:
1. partially defective memory;
2. corrupt files or Windows installation in the boot hard disk; and/or
3. IDE cable, motherboard, the hard disk itself and others.
If it is a memory problem, try removing the memory sticks and clean the gold pins with a pencil eraser, re-install and make sure seated correctly. Reboot and try again.
If it is a corrupt file, insert an OEM Windows XP Installer (bootable) CD into the PC and when prompted, press any key to boot from CD. Once in the setup menu, press the "R" key to repair Windows. Log into by pressing "1" key and then enter.
You would need your administrator password, then hit enter. You need to copy the missing file(s) from the CD to your HD. Type :
copy D:\i386\ntldr C:\
copy D:\i386\ D:\
Soon as copied, reboot.
If thereafter, other files turn out to be missing also, perhaps you might be better off formatting your HD and re-installing your OS since chances are not only 1 or 2 files are already corrupt.
In some cases, even a re-install will not solve the problem, you then may either have to replace your memory or your hard disk.
Hope this be of some idea/help. Pls post back how things turn out or should you need additional information.
Good luck and kind regards.
Nov 03, 2007 | Toshiba Satellite A15-S157 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
119 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
