Question about Sony SDM-X95KB (Black) 19" LCD Monitor
Switching back to regular pc mode from TV mode...
Hello all
i have a slight problem...I have a Sony SDM-X95KB 19 (i think), i one day right clicked on my desk top and saw that a drop down menu came out and i had an option to switch to TV MODE on my pc....now my screen went completly black. when a long time goes by the screen saver comes on and i can only see the floating windows xp logo.
ive tried right clicking but i dont see the drop down menju anymore. i also took it (my pc) to BEST BUY and they they found nothing wrong with it but coencidently found 110.00 worth of other problems that they fixed with a prepaid amount and with out asking they "fixed" everything else but my problem.
CAN ANYONE HELP PLEASE.
RVJ
SOURCE: Sony Monitor ... SOMEONE HELP, please!
It's funny when reading sweetanne post on her Sony LCD SDM-HS73 Monitor which I also have ,I could copy her word for word ( I own a Sony LCD SDM-HS73 Monitor, its almost 4 years old. Never had any problems with it until now. When my computer has been turned off for awhile, and I turn it back on, the monitor green light comes on, but the screen is black. I have to uplug the monitor from the power supply, and when its plugged back in, everything is fine. ) Only mine does come on but it takes anywhere up to 15 minutes to come on and I've noticed with the green power light on I cant press to shut off unless I'm shutting the computer off.. Sony was no help gave me a number to call so I called it and yes up to $200 to fix if they can so for the time I will just have to put up with this. :-(
Posted on Sep 27, 2007
  • 3 Answers
SOURCE: Black screen after 1/2 second power-up of Sony SDM-HS73
bratty, do you have a pic on which capacitor this is? Also where I can find a replacement one.
My monitor is doing the same thing, nice and bright for 1/2 a sec then goes super dull, you can barley see anything.
Thanks,
Jake
Posted on Dec 18, 2007
SOURCE: PS2 RGB SETTING
You need to get either an a/v or s-video cable and plug that into your tv and ps2 and start it up. you should be able to see the menu then and switch it back.
Posted on Dec 28, 2007
SOURCE: Sony SDM-HS73 Not Staying On
The problem is with power inverter, usually the capacitors go bad and need to changed, they might be bulged and or leaking. Very cheap fix, less than a buck apiece and an hour with a solder iron. Google it to find more info.
Posted on Feb 20, 2008
najah
  • 180 Answers
SOURCE: MY SONY SDM-HS74P
You open the inverter unit and check any dry soldering is there. Some times dry joints inside the inverter unit cause this type of problems.
Posted on Apr 08, 2008
My Philips TV screen is showing: SDM;0000 L90AT2 1,4; SY 55;0 251 7 0 0 255 0; ERR 710 0 00. When I switch on the tv for the past 3 days.
The TV has entered the SDM mode [Service Default Mode]; by anyway. Might be due to wrong presses with the remote control buttons. You should make it to normal mode; from this SDM mode, to work it properly. Contact any service technician; or the authorized service centre for Philips.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Nov 17, 2014 | Televison & Video
Power light lights up but monitor dont come on
HI,Dear Friends..
Do you hear the hard drive working and see the LED flickering? As you can't see the screen to log on, Windows will stop at that point.
> If you have a spare PC monitor and VGA to VGA lead check it.
> And your keyboard working properly or not, if NUMLOCK light on it means your hard drive is OK.
> Your Monitor light on/off regular, or not? if light regular blink then power come but VGA section not working. So please contact Monitor Engineer.
Thanks...
Feb 13, 2013 | Sony SDM-HS93 19" LCD Monitor
I have a Sony SDM-HS93 (Black) 19 I turn the monitor on and it flashes on then off and on again. does this continually.. any answer for me? I have opened the back and checked capacitors and all look...
It may have bad lamp assemblies, you need the inverter tester lamp to verify. See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
This is common problem with the 17" version also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 10, 2011 | Sony SDM-HS93 19" LCD Monitor
I suddenly get an Information Box stating Model SDM-HS95 and a serial number on the monitor. Does this mean I need a new monitor?
You are precisely right. This happens in Sony models. Have expirienced a lot of this problems relating this issue and all of them have been on Sony and Viewsonic LCD 19" and 22".
Sep 01, 2010 | Sony SDM-HS95 19" LCD Monitor
Hi..my sony model sdm-hs93 lcd monitor flutters for a couple of seconds right before the screen blanks out. But, if I leave the monitor on for a day in sleep mode, the next day i can hook it up to the...
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 16, 2010 | Sony SDM-HS93 19" LCD Monitor
ETI information box appears on SONY SDM-HS95 monitor repeatedly
You might try checking you monitor setup, you should be able to shut it off by unckng the proper box
Apr 29, 2010 | Sony SDM-HS95P/B 19" LCD Monitor
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Display orientation issue
Right click the mouse on an open area of the desktop, In XP select properties; Vista it's personalize. Go to the display settings and make sure it is set to portrait. Hope this helps.
Jul 02, 2009 | Sony SDM-HS73P 17" LCD Monitor
SONY SDM S81R
hello sir,,
since there is a problem with the monitor..u have to contact the sony vendor ,
u can contact them in 800-326-9551
n also 888-476-6972..
thank you
have a great day
Jul 06, 2008 | Sony SDM-HS75 17" LCD Monitor
Vertical size
LCD monitors auto adjust and use a fixed resolution. It's impossible to reduce the vertical scan. The only what I could think of is to specify a widescreen resolution if the monitor is not widescreen and this may only work if you are connected by DVI cable. Sorry!
Jan 16, 2008 | Sony SDM-X95KB (Black) 19" LCD Monitor
Sony SDM-X95KB (Black) 19" LCD Monitor Logo
37 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
