Question about Samsung PCJ522R 52" Rear Projection Television
On of the projection lamps is on it's way out.
Is there a way to adjust the intensity of the lamp until i can get a replacement?
    Genius:
  • 1,067 Answers
Nope change and adjust britness and contrast
Posted on Jan 29, 2008
My 50 inch RCA Projection TV has lighted pixels (
IF IT USES A LAMP AND HAS THIS -- the problem is inside the optical light engine--a lot of them get damaged from the intense heat from the lamp which shines directly into the engine.
Jun 16, 2012 | RCA M50WH92S Rear Projection TV Lamp
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Hi there i have a sony grand wega kf-42sx300u and the red green on off light started flashing and then the lamp light comes on i guess its just the lamp that needs replacing .. i've had the tv about 6 six...
The lamp is generally rated at 2000 hours so I would say you have done quite well. You must not watch too much TV as that would equate to a little more than 1 hour a day. There are a number of online resources where you can purchase a replacement lamp such as partstore.com and others. As I recall you will need to remove the lower trim panel to expose the lamp compartment to gain access for replacement. One key to long life on any set that uses a high intensity lamp is to allow the TV to go through its normal "cool down" cycle. Never have your sets AC power interrupted before the set cools down. After the set is shut off the fan keeps running until the unit cools sufficiently. This prolongs the life of the lamp. Some stores would have all their sets on a power strip and cut AC power instantly at the end of the day and consequently replaced many expensive lamps that could have lasted much longer.
Nov 20, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Replaced bulb,still not turning on-power flashes green then red and lamp light comes on
Did you reset the lamp timer? If you replace the lamp and dont reset the lamp timer the TV will continue to display the lamp error until you do.
Sep 22, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Low intenstity on green lamp
sounds like the Green CRT need to be replaced. Thats fairly common with your model with that symptom. If you need a link to where you might be able to get a replacemeny let me know.
Jun 07, 2008 | RCA P52955 52" Rear Projection Television
Adjustment
Hi, no adjustment should be needed after a new lamp is installed, if you installed a new lamp and the picture is not correct you have another problem, BMW Rider
Jan 03, 2008 | Hitachi 50UX57B 50" Rear Projection...
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Samsung PCJ522R 52" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
