Question about Frigidaire FRS23R4A Side by Side Refrigerator
Particles in Ice Cubes
I just bought my house and this fridge came with it. The previous owners said they never liked the taste of the water so they never used it. When I changed the water filter, it was completely green with bacteria and the water had crap floating in it. I flushed the water for about 10 minutes and it still runs very slow, but it is completely clear. The ice maker however has crap floating in the ice. When you look at the resivoir, it looks like there are 2 lines. The one that goes straight up and not through the coil is brown in color as where the one in the coil looks clear. Does the Ice maker not use the filter? Is there a way to clean the lines?
Thanks in advance.
I whould tac the xcbgkvoxchcgdhfjg
hfggfsrfkghghghjgcz
Posted on Dec 18, 2008
I dont know what to say about that would that be the first thing you would really check i dont really have a solution
Posted on Nov 01, 2008
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
How do i get clean ice cubes from frigidare?
In order to get as clean an ice cube as possible, it all depends on the quality of the water that goes into the ice maker. If you have a water softener, your cubes will always be a bit cloudy, since the added salt slows down the freezing slightly and thus the cubes get cloudy.
That said, there are a few things you can do to improve your water. Adding a whole house water filter with a sediment charcoal filter, will remove the impurities and help to improve the overall taste. Then add an inline charcoal filter on the water line into the fridge. That will filter your water a bit more and help further improve the clarity and taste of the cubes.
Beyond that, you might want to look into a reverse osmosis system to really get the best possible tasting water you can.
The old adage of "garbage in, garbage out" is a good analagy for water quality issues, so you need to figure out what's in your water in order to take the steps to treat your water for the best possible results.
I recall that Sears offers free water testing (to help sell water softeners) so that's an option, as well as getting a home water test you can perform yourself.
Hope that helps you with your situation. Best regards!
Jul 31, 2009 | Frigidaire FRT17G4B Top Freezer...
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice Machine's Ice and Water taste like mud!
go to sears.com enter the model number and you can get an owners manuel and should be able to order replacement filters.
Apr 25, 2009 | Refrigerators
Strange taste in ice cubes
Did you use new water lines? If you did then clear the icecubes from the tray and use an appliance store cleaning solution to wash it out with. their solution is designed for fridge use and wont leave an after taste......Rinse well...... Also for awsome Ice......Install a large in-line water filter.... Makes mine taste like frozen mountain spring water with no nasty taste or smell. Hope it works for ya!
Jan 04, 2009 | Jenn-Air JCB2388G Side by Side...
Particles in ice cubes
Most new water/ice systems have break-in procedures in the manual, including flush a couple gallons of water through the water dispenser and disposing the first 24hrs of ice.
Are the particles present in the filtered water before adding ice? If so, you can probably assume the contamination is from the water tank so you should flush several gallons of water through the system to get rid. If the particles are present after adding ice, try pulling out the ice bin and dumping the ice.
Dec 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer burn on ice-cubes
Black mould around the freezer seal is normal if it has built up over a long period of time or has stood in damp environments. Normally hot soapy water can clear this right up. The ice taste would probably be resolved by fitting or changing the water filter, and / or cleaning the ice maker module located at the top of the freezer section and any route that the ice would take. Cleaning solutions for ice makers are available you just might need to call a local engineer for some advice on where to get some in your area. Hope this helps.
Feb 07, 2008 | Refrigerators
Frigidaire FRS23R4A Side by Side Refrigerator Logo
618 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
