Question about Nu Mark AXIS 9
There Is No Power For The Axis 9
I turned both CD players on, 5 minutes later, both CDplayers made a pop noise, then smoked from the back, and then all power just stopped goin in to the devices,
wont turn on at all now
what is the problem, and how much will it cost to fix?
cheers
  • David Chaos Apr 12, 2008
    i had not used my Axis 9's in a while- they had some dust on em. they started smoking and it smelled like dust- then one works fine but one has NO power at all. the one that smoked the most is working fine right now.
The 10,000 microfarad capacitor in the power supply is shot. Have someone that knows what they're doing replace it. They should be good at soldering AND know how to tell polarity. If you get it backwards it'll be spectacular, but won't be good! ;p
here's the link.
http://www.numark.com/products/parts.php?id=AXIS%209
Capacitor (C901) 16V 10,000 Micro Farade | EC10916 $2.00 USD
Posted on Aug 14, 2008
  • 1,512 Answers
That sounds bad. You will need to get someone to have a look at the decks for you. The fact that both blew sounds like they got a major power surge or are on the wrong mains voltage. check to see that they are setup for operation in your country. Check your mixer for damage also.
Some suppliers of electricity are bound by regulations to keep supply within 5%. When you have a spike that "blows" stuff, they generally know about it and there may be some recourse with the electricity provider. Worth checking out.
Posted on Jan 29, 2008
My Kenmore gas range 2274233 makes a loud noise when the oven is turned on.
Since it is new--have them bring you a new one. That should have been fixed before shipment
Jun 26, 2014 | Kenmore Kitchen Ranges
Cd music is skipping on bose 321 system and one channel of dvd audio will stop playing. Disk player has also started making loud vibration noise after loading dvd or cd. This didn't used to happen. On CD...
The Bose® 3·2·1 GSX Series III DVD home entertainment system puts you at the center of exciting home theater with just two visible Gemstone® speaker arrays and a hideaway Acoustimass® module. Setup is simple because, unlike traditional five-speaker surround systems, there are no center or rear speakers. An elegant media center features a progressive scan DVD/CD player with an HDMI output and AM/FM tuner. You'll enjoy vivid detail in your movies and sports with video resolution up to 1080p over HDMI.
Apr 04, 2010 | Bose 3 2 1 GSX System
My Whirlpool Gold dryer makes a high-pitched squealing noise for about 5 minutes when first turned on, then stops and dryer continues cycle. The noise doesn't sound like metal on metal but more like a...
CHECK BELT,TENCHEN ARM (KEEPS BELT SNUG),ALSO ROLLER WHEELS...
SOMETHING IS GOING BAD BUT ONCE IT WARMS UP IT STOPS MAKING NOISE.
YOU NEED TO FIND THE PROBLEM BEFORE IT BREAK DOWN???
LATER FREDDY
Feb 11, 2010 | Whirlpool Dryers
My hp notebook just shut off,wont come back on
Sounds like a burnt out capacitor. Either on motherboard or power supply.
You can try taking out battery, press and hold power button for 5 seconds, put back in and try to turn on. If it doesn't turn on, then I'm afraid motherboard is bad or memory card is faulty
Nov 11, 2009 | HP Pavilion dv2610us Notebook
While playing a CD, my Nakamichi Receiver 2 made a ''pop'' noise and lost the signal, with some smoke coming from the top vent near the front. It was in a confined area, and I believe it overheated and...
The output section has a problem. The receiver is in "protect" mode and wioll not turn on the speakers. This unit needs service. In all likelyhood, one or more of the output transistors has shorted and hte smoke came from a resistor that fried. This is a relatively simple repair for an audio repair shop. Figure around $40 for parts for this repair.
Dan
Oct 05, 2009 | Nakamichi Audio Players & Recorders
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
Apr 04, 2008 | Philips CDR796 2-Disc CD Recorder
CP-S335 popping noise when powering on
Hi Eva
A Projector does'nt like being switched on and off all the time , if you are going to watch a couple of movies - rather leave the machine running all the time - this will also help you to get more hours out of your lamp - and that's a promise.
As far as the noise is concerned - it is most probably just the machine that was not cooled down properly at that stage.
Apr 02, 2008 | Hitachi CP-S335 Multimedia Projector
Axis 9 CD Deck
did u buy new take it back man bad power sourses no good make sure u plug into a good power sourse witha good monster power strip ok ect did u buy on ebay get refund with paypal make a claim
Jan 29, 2008 | Nu Mark AXIS 9
Nu Mark AXIS 9 Logo
171 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
