Question about Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C problem
My MFC-210C has "unable to clean" problem, and I checked everywhere, there is no jammed paper.
  • Brother Master
  • 1,113 Answers
Press menu,blue button and up arrow 4 times , what number do you get?
If you spin a error 41 you in for bad news needs head, too expensive. 46 is waste full will need to replace the waste tank inside the printer and reset the counter. plus many more...
Posted on Jan 29, 2008
"unable to init" message appears on my MFC 210c
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Feb 03, 2010 | Brother MFC 210C All-In-One InkJet Printer
Screen says
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything! You will need to see an authorized service center for repair.
Jan 27, 2010 | Brother MFC 210C All-In-One InkJet Printer
My brother MFC-210C says unable to clean,opened it all up no paperjam
With no jam, it might mean that the ink absorber is full, Not an expensive part, but a shop needs to do it and reset the count.
Jul 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C with error code 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
This should put you in the maintenance mode menu.
Enter 80, then scroll down with the arrow down (round) key.
You'll find an entry listed as purge count.
If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart your printer and it should work just fine !
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to clean?
Heres the mauel for the MFC-210C printer.
http://www.brother-usa.com/manuals/default.aspx?PRODUCTID=MFC210C&ProductGroupID=5
You can clean the outside of the printer and the paper handling mechanisms with a mild cleaning solution and a lint free cloth. To clean the insdie of the printer, use a HEPA vacuem and follow the manuels recommendations.
Nov 10, 2008 | Brother MFC 210C All-In-One InkJet Printer
BROTHER MFC210-C "UNABLE TO INIT"
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
How to replace back cover of MFC-210C?
There are two clips on either side which need to be squeezed together then the cover can be slipped back into position.
Apr 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Unable to print
press menu then start mono (blue button) then fourtimes arrow up (tel-index). Machine will be in maintenance mode and lights will flash. What error code does the machine display?
(to leave the maintenance mode press 9 then 9)
Nov 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C
hi this a fateful malfunction only a technician can fix this good luck
Apr 06, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
518 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
