Question about Nu Mark AXIS 9
Axis 9 CD Deck
Brand New CD Decks, turn both on, lasted about 5 minutes, both started smoking, power was cut to both CD decks
still not got any power
  • podgeoj Jan 29, 2008
    i got from a shop, but lost the reciept
    well the thing is, the shop i bought it from has shut down now,
    do u know what the problem is exactly?
    and how much it might cost?
You probably had the switch set to 110volts if u were using 240v or the other way round
Posted on Jun 02, 2008
    Genius:
  • 1,067 Answers
Did u buy new take it back man bad power sourses no good make sure u plug into a good power sourse witha good monster power strip ok ect did u buy on ebay get refund with paypal make a claim
Posted on Jan 29, 2008
  • Anonymous Jan 29, 2008
    they will have it on file take itto them toamor get differt ones like numark mine lasted 8 yrs now love it
    power suples and the actulay brain in it they dont sell parts maby on ebay u can find spare ones parts best bet even then changing that out couve fryed more of it best bet is to get new oens good brand
6ya staff
SOURCE:
Sony TC377 Tape Deck - switched the deck and left a reel to run but did not work - few minutes later there was loud bang and smoke coming from the fuse box area. Disconnected the power supply. Is it
It is hard to determine a repair cost with a description like this but sound like a capacitor blew and that should be obvious when it is looked at. Probably took some fuses and a bridge rectifier with it or it might even be a motor run capacitor- you need to tell us which caps blew up.
Jan 31, 2013 | Sony Audio Players & Recorders
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
WHY IS CUT UN EVEN? MOWER LEAVES LINES IN LAWN
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
2. Level the deck following the instructions in the manual
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My axis 9 wont play burnt cds
I'm having the same problem with the Axis 9 I just purchased on eBay. And so is the person who posted "Numark Axis 9's. . Problematic. Ahhhh!!!" Seems ridiculous that this would be so common. I definitely don't want to re-burn 100's of CDs just to use this CD player.
Nov 08, 2009 | Nu Mark AXIS 9
Numark Axis 9's wont turn on
1. Check for internal fuse.
2. Check the power transformer.
3. Check the rest of the power supply.
Aug 11, 2009 | Audio Players & Recorders
No rear output
yea your ic in the deck is going so i suggest you buy one which is cheaper than buying a new deck
Sep 15, 2008 | Pioneer DEH-P5800MP CD Player
There Is No Power For The Axis 9
that sounds bad. You will need to get someone to have a look at the decks for you. The fact that both blew sounds like they got a major power surge or are on the wrong mains voltage. check to see that they are setup for operation in your country. Check your mixer for damage also.
Some suppliers of electricity are bound by regulations to keep supply within 5%. When you have a spike that "blows" stuff, they generally know about it and there may be some recourse with the electricity provider. Worth checking out.
Jan 29, 2008 | Nu Mark AXIS 9
Axis 9
i have exactly the same problem, its annoying
1 thing which works is holding the button down then spinning the deck round, let go, turn off the scratch button, press play and turn on the scratch button again
Jan 15, 2008 | Nu Mark AXIS 9
Problem with numark axis 9!!
Hi, I’m from Yucatan, Mexico. I’ve always used Numark cd players, I have two Axis8 and two Axis9, and one day I had the same problem with an Axis9. I know a little bit about electronic so I opened the machine and began check it, I took the decision to change and electronic part, I took it from the another Axis9 which was working perfectly, this part is the memory, buffer, effects and it controls all the front panel, jog, play, pitch, etc. I discovered the problem, this electronic circuit part was wrong, I thought that it was impossible to repair so I began to investigate. I visited Numark web site, they sell any electronic part you need, I bought a new one from Numark Company for 200 dollars, and this is the most expensive. They sell parts for Dual Players, Axis, CDX, Mixers, etc. If I not wrong you need this part, now it costs 174 dollars: TWPC01C04603 PCB, Effects/Buffer - Axis 9 (Red) | I got it and my Axis9 works like new again!!! Good luck with yours!
Jan 04, 2008 | Nu Mark AXIS 9
Cd players locks up when power switched on
arg... email numark they will give you a uk brach to email - there is a reset facilty that may help you (sorry cant rememeber the buttons it was yonks ago) while it sorted mine 'scratch' is now permanently lit only... they suggested a servide to clear that one prob but got used to cueing the record on that deck in scratch mood which is an art in itself lol
Sep 18, 2006 | Nu Mark AXIS 9
Nu Mark AXIS 9 Logo
147 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
da surgen
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
