Question about Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ)
Whirlpool ice maker door shute
How do you get the cover off the front of the door on a whirlpool icemaker so that a new chute can be installed.
  • coloradobeer Feb 28, 2009
    I have the same issue, I need to remove the cover. I do see the two slots on the bottom of the cover, I can stick the screw driver in the slots and turn clockwise, nothing happens. How much "force" is needed to pop the cover. It looks like to me that there is a retaining strap that is holding the bottom together. I do not want to break anything here.
  • 65 Answers
Look at bottom edge underside . put screwdriver in slot as vertical as possible and pry by turning screwdriver clockwise while stillholding vertical.repeat at ather slot
Posted on Feb 16, 2008
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
You will need to replace the module. It is accessed by removing the white, plastic cover from the front of the icemaker. Once off, remove the three brass colored screws and disconnect the wire arm on the RH side of the icemaker. The new module will install in reverse order. The module is available at the link below.
Module $48.50
May 25, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Kenmore fridge106.56546400, icemaker shute leaks
Most likely the chute is not closing all the way. Warm air enters and melts some ice and drips. You'll eventually get a frost buildup there if not already. Order a ice door kit. Get a flashlight and look at the chute door real good for a partial closure for verification.
Oct 12, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Whirlpool refrigerator with an ice maker and when the icemaker is filling with water it leaks from the front of the tray into the ice storage bin.
1. icemaker is not level. (check and re-level)
2. icemaker has a crack in the mold.(replace i/m)
3. Water level set too high.(remove front cover and adjust water level screw counterclockwise)
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I replac the clear plastic cover over the ice shute on the
order the chute assy old pull out and down holding the lever as to not break it other snaps in reverse order
Aug 19, 2009 | Whirlpool ED5FHEXMQ Side by Side...
I have a Whirlpool side-by-side refrigerator and I can't get the icemaker front panel off to install a new icemaker kit in order to fix the frosting around the icemaker chute. How does the icemaker front...
according to the model number that you listed in the heading it just shows a cover door that slides out and down and is attached to the top freezer shelf. is this correct? If so pull one side of the slide and it will release the cover.  Now if your talking about removing the dispenser cover on the fron of the freezer door there are 2 slots on the bottom of the cover that you insert a flat tip screw driver and carefully pry the cover off. hope that helps Peyton
Jan 27, 2009 | Whirlpool ED5VHGXM Side by Side...
Front of in door Icemaker door spring fell out!
Any chance of some photoes may be able to figure out if have some pics.
Jul 19, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice shute does not seal
There is a plastic clip that has broken off of the icemaker chute door spring latch on the refrigerator door. This is a common problem and a replacement kit is available from whirlpool to correct this problem. If you contact whirlpool directly they will help you out with a part number for the kit.
Mar 12, 2007 | KitchenAid KSBS25FK Side by Side...
Frost on Ice Maker shute
Dtot, does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Whirlpools where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Whirlpool and inquire about the aforementioned. If this is your case, there is a good chance they will cover it. back.
Oct 21, 2006 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ) Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
