Question about Hitachi 43FDX20B 43" Rear Projection Television
Front cover won't latch - Hitachi 43FDX20B 43" Rear Projection Television
  • 1,512 Answers
The atch has broken. put a small piece of bue tack at each corner of the door. press it home, and it will stay.
Posted on Jan 29, 2008
    Genius:
  • 1,067 Answers
Buy heavy duty velco strips at store use inplace if its a small door use small round valcro in middel of it ok
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Pontiac Vibe hood won't latch
the problem for me was an internal spring that was rusted and thus frozen. the quick fix is to pop off the small plastic cover in front of the latch and pack a lot of thick grease into the openings of the latch to reach the spring. worked for me
Aug 18, 2012 | Pontiac Vibe Cars & Trucks
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
Cherokee 1998 hood latch won't open.cable frozen ?
frozen or broken. try a good whack on front on hood while someone pulls latch, see if you can free it up. no luck? try pounding at driver's side near the windshield while someone pulls latch. no luck? You can crawl under front with a screwdriver and reach up and try to release the latch manually. push the little lever the cable attaches to over towards driver's side. good luck. When open, see if cable operates latch: if good spray it liberally with penetrant. If your cable is broken, just get a new one or visit a salvage yard. The hood latch can be adjusted a small amount.
Oct 22, 2011 | 1998 Jeep Cherokee
Bought new toner cartridge. Cannot figure out how to remove it from the printer. The 1 & 1/4 Hi X 9 inch door does not provide any handle or way to pull it out. Help. Bought new in Feb 2011
The drum and toner can become stuck in the machine if the develop joint link is not attached properly.
1. Open the front cover.
2. Remove the drum and toner.
- If you are able to remove the drum and toner, the issue is resolved.
- If you are unable to remove the drum and toner, continue to the next step.
3. Looking into the interior of the machine, there should be a plastic latch (develop joint link) on the left side of the machine that is connected to the front cover (connector), an inch left of the manual feed slot. This plastic latch is usually not the same color as the front and side cover.
- If the develop joint link (plastic latch) is there but not connected to the connector on the front cover, continue to STEP 4.
- If the develop joint link (plastic latch) or the connector on the front cover is broken, go to STEP 5.
4. Pull the end of the develop joint link (plastic latch) towards the connector on the front cover. If the develop joint link (plastic latch) pulls out, pull it gently to the left of the connector and then push it over the connector, securing it firmly onto the connector. Remove the drum and toner.
- If you are unable to remove the drum and toner or secure the develop joint link (plastic latch) onto the connector, continue to the next step.
5. Pull the end of the develop joint link (plastic latch) towards the connector on the front cover. Keep the latch pulled out and remove the drum and toner.
Aug 31, 2011 | Brother HL 2270DW Laser Printer
Latch won't close on dishwasher
Possible that the latch has gone out of aligment in which case you can remove the front cover or look through the bottom, you can move you hands up to sense the lock so as to get the postion corrected.Use some degreasing spray like WD40 to clear off dirt in the latch
Please check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3/1288/how-to-fix-a-broken-dishwasher-door-lock-hotp.html
Aug 24, 2011 | Dishwashers
How to open cover mobil nokia n70
There are 6 latches all in all. 2 in the bottom part, 2 about 1/4 for the top (in line with the top of your screen) then 2 in the top part. First remove the bottom 2 latches. I would suggest to use a jeweller's flat head screw driver or similar. Then slide the screw driver up one side to the latch that is about 1/4 from the top - it is in line with the top of your screen, this latch should pop off. The cover is fairly strong but do be be a little careful about breaking it.
Then the other do the same on the other side, after that every thing else is easy, pull the front cover carefully from the middle latches then slide the cover upward. If you do all this carefully then you will have successfully removed the front cover.vote me if this works.thanks!
Jun 16, 2010 | Nokia N70 Cellular Phone
Unable to remove imaging drum - Dell 5110cn Color Printer
When you open the front cover it is possible for the transfer roller assembly to remain latched against the imaging drum assembly, making it impossible to pull out the imaging drum. The drum should lift out very easily. If it doesn't, try closing the imaging drum cover and then the front cover (ie: put everything back the way it was). Then open the front cover again, pressing firmly on the front cover latch. When open, check that the transfer roller assembly stayed with the front cover and swung out of the way of the imaging drum (you may have to swing it yourself. When the front cover has opened properly, the imaging drum's cover will unlatch easily and the drum can be pulled out.
I hope this helps someone! I had to say many bad words before I figured this out. Good thing I had a second 5100cn handy to look at for comparison. - B.Till
Nov 06, 2009 | Dell 5110cn Laser Printer
ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
How to open this box for gateway e-2000
The front cover for that Gateway in my picture is hinged at the top front corners; the inside surface of it is showing face-up (black) on the top of the case. Flip it upward, around and down to cover the front panel; on the top of the left side cover there's a press-in latch button (kinda rectangular, in the recess that the front cover was hiding). Push that latch button in (toward the outside surface of the side panel) then pull the top of the panel outward and down, away from the case as if the panel was hinged at the bottom. Once the panel's at a 45º angle, you can lift it up and away from the case.
Your case is similar, I'm sure. Look for a semi-hidden latch button hiding in the recesses.
also check ou this link
click here
plz rate this post as good as u can, so we can help others.
Jan 30, 2009 | Gateway E-2000 Deluxe PC Desktop
Hitachi 43FDX20B 43" Rear Projection Television Logo
22 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
