Question about LG 42LC2D 42 in. LCD HDTV
42" lg blinking in 16:9 ratio
The tv blinks on 16:9 ratio but doesn't do it on 4:3.....what could it possibly be?
Bad cable and or connection.
Posted on Feb 06, 2008
Can't change Aspect Ratio
Check the settings on your laptop to make sure it is outputting a resolution that the TV will support.
Mar 21, 2014 | LG 42PC3D 42 in. Plasma Television
Lg tv take too long to start
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Feb 24, 2014 | LG 42LN5200 42" 1080p LED-LCD TV - 16:9 -...
Blinks 6 times
This is normally a fault code,a tv engineer would know.
Jan 25, 2014 | Panasonic TC-P42S30 Plasma TV, 42 Class -...
Cannot get full screen picture. seems like I still have a 36 inch tv. It is a 42 inch LG plasma hdtv
It seems like you're expecting a 16:9 ratio picture. If you're sending a 4:3 ratio signal to the TV, you'll get a 4:3 ratio picture. An option would be to use the remote and set the TV to a 16:9 ratio picture, but that'll stretch the picture and make everything look fat. Another option would be to use the remote and zoom in, but that'll chop off the top/bottom of the picture a bit. Either case would be annoying. Some make matters even more annoying, some programs are broadcasted in a 16:9 ratio signal, but the actual picture is really 4:3 ratio. So...... as long as the pictures don't look skinny, fat, or chopped off, just accept it. If you're really that picky, just watch new Blu Ray movies only.
Jul 22, 2011 | LG Televison & Video
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
Letterboxes on my LG 42" LCD HDTV...
Have you tried the Aspect Ratio button on the remote control, this will change the oicture size through 4:3/16:9/ etc.
Mar 22, 2010 | LG 42LC2D 42 in. LCD HDTV
I have an 42LG50 and the picture is now a smaller box on the screen and the manual is now help in enlarging the picture, any ideas?
You possibly have the screen set to the 4:3 ratio. On the remote control use the aspect ratio button to toggle through the different size screen formats eg 16:9 etc. this will enlarge the picture to fill the screen.
Nov 08, 2009 | LG 42LG50 42 in. LCD HDTV
LG 32'' LCD TV aspect ratio self switching
I have an LG LCD TV with the same problem.
The solution is to go to
MENU
OPTIONS
FACTORY RESET
And select HOME rather than STORE on initial setup.
Mine was set to store as it was a display model.
That means that whatever picture setting you make they will reset after 10 minutes.
Nov 19, 2008 | LG 42LP1D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
47 people viewed this question
Computer Repairing
Computer Repairing
