Question about Hitachi 43FDX20B 43" Rear Projection Television
16 : 9 overfills screen
My aspect is standard but the picture overfills the screen (top & bottom cuts off)
    Genius:
  • 1,067 Answers
On what sd tv or hd tv native is on 16.9 then take zom off or wide fit
Posted on Jan 29, 2008
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
How do I see the hole picture on my Philips match lll line. Black corridors on each side cuts away the sides of the picture. /t
You may actually be looking at the entire picture. The newer televisions have a 16:9 aspect ratio (16 units wide for every 9 units high). The older sets had a 4:3 aspect ration, and a lot of material was made for the 4:3 screens. There are three ways to look at this material on a wide screen set: use the "shadow box" you describe, stretch the picture sideways to fit the screen, or expand it to fit width and lose the top and bottom of the picture. Your choice depends on the material and your personal preference.
Now, if you know you are looking at wide screen material, you need to correct a setting in the view format options. These settings go by various names in the instruction manual and on-screen menus - "resolution", "aspect", or "display format" are common. I haven't seen the menus on a Phillips set, so I don't know what term they use.
Oct 24, 2010 | Televison & Video
The picture is to ig for the screen in any mode - i have it on full and it cuts everything off teh top and bottom sony bravia
try checking the aspect ratio settings on the device feeding the tv if applicable, i.e set top box, DVD player, etc
Ensure the settings match the tv type, e.g, 16:9 for a widescreen tv. 4:3 may cause cropping of the top/ bottom of the picture if this is set
Jul 02, 2010 | Televison & Video
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The bottom and top of the picture are being cut off
Check your remote for a "zoom" or "picture size" button. Press this button to adjust the size until everything fits back on the screen.
Please take a moment to rate this solution a fixya if it's helped with your problem. Thanks for asking here!
Mar 21, 2009 | Vizio L32 32 in. LCD HDTV
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Cant see all of screen
You should have a button or setting on the remote that says "picture size" or "aspect". One of those is set too "zoom" mode which will cut off the bottom and top of the frames. You want it to be in 16:9,Normal or Full mode (or whatever your set call it) to get the correct aspect. Or if you have a HD satellite rcvr. you might of placed it in the zoom mode as well.
Apr 25, 2007 | JVC HD-52Z575 52" Rear Projection...
Picture not fitting on screen
if your tv has a warranty take it back to where you you bought it.or check if your remote has the zoom feature,if it does zoom it back.or else you will have to call the repair man to program it for you.
Mar 23, 2007 | JVC AV-29LX 29" TV
Hitachi 43FDX20B 43" Rear Projection Television Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
