Question about Microsoft Windows XP Professional
Jumpy 3D graphics
I recently installed Windows XP on a brand new machine and found that in certain games, and in the standard Windows 3D screen savers, the video is very jerky. In 3D Flowerbox, for example, the object will constantly flash ahead of where it's supposed to be, then back, causing it to sort of flicker back and forth. For what it's worth, in the preview window it does the opposite: it will flicker back to where it's just been, rather than where it's about to be.
The games I've noticed this in are typically older top-down RTS style games, where when I scroll along the map, it will keep jerking back and forth. If I scroll right, it will move right, but keep flashing a little to the left as it's doing so.
In both cases, restarting the computer (not just the game) will make the problem go away for a while, but then it gradually creeps back, and just gets worse and worse until I reboot.
I'm running an AMD Athlon dual core processor with a GeForce 8600 GTS video card. I have both the latest video and DirectX drivers.
Thanks in advance for any help you can give!
  • Thalomarre Jan 30, 2008
    I've reseated the video card, making sure it was in securely, but to no avail.
    There's another symptom I've discovered that I thought was with only one game, but have since found affecting several different games: sometimes, things will suddenly speed up. In some games, it affects every aspect of the game but audio, as though someone had hit fast forward. In-game video clips will go so fast that they'll quickly end up out of sync with the audio and end long before the audio is finished. Same goes for lip-syncing in Neverwinter Nights 2, as I've just discovered (though oddly enough, I've only noticed it with lip-syncing in that game; other aspects of the game seem to stay at normal speed).
    Thus far, I haven't seen these effects in Windows itself.
    I believe this is related to my other problem, as it seems to get worse the longer it's been since my last reboot; just starting the game over doesn't fix it.
    After some extensive research, I've managed to determine the source of my problem: my dual-core CPU. If I alt-tab out of a game, right-click on its process in the Task Manager and click "Select Affinity", and deselect one of the CPUs, the game in question suddenly works fine (if maybe a little less smoothly). I've tested this on games that exhibited either problem I mentioned above.
    So now my question is this: is there anything that can be done to solve this issue without going into the Task Manager every time I start a game? I can live with this as a solution, assuming I won't have any such problems with newer games designed with dual-core processors in mind, but if there's anything easier, I'd be much obliged.
    Maybe something in BIOS that I don't know about. I'm pretty unfamiliar with how dual core CPUs work, but in the cases I mentioned where the graphics jump back and forth, I'd say it's as though the two CPUs were somehow "out of sync" and couldn't agree on where any object should be at any given point in time.
  • 778 Answers
I would re seat the Vid. Card first, and make sure it is in the socket tight, and if that doesn't do it? You probably should try another Video card to eliminate the possibility that the problem isn't with the Video Card in question.
I hope this helps you!
Posted on Jan 29, 2008
I installed a game on acer aspire 5315 but it will not load due 2 d3dx9_41.dll missing. any help plz
Simply please try uninstalling the game and reinstall. If you are using a Windows Xp machine and it is a Laptop then it is likely the graphics card in the machine is not able to handle the level of graphics being displayed in the game.
If you are checking the graphics card driver you may want to take note of any stickers on the machine indicating the brand of graphics card for example if it is a NVIDIA graphics card you will need to go to the NVIDIA site download and install the most recent graphics driver for the card and try again. If it fails it is likely the video card not being able to handle the levels of graphics as mentioned before
Jan 21, 2015 | Acer Aspire 5315 Notebook
Can you tell me how to find out if I have "3D videocard" on my computer. I need this for the games I'd like to order. Thanks
3d video cards are relatively new so if you've didn't recently install a video card, chances are you don't have one as 3d video cards do not come standard in most computers. That said, go to Control Panel then System then Device Manager Expand Display Adapters and you should see the model number of your graphics card. Google that and you'll be able to see if 3d video card or not.
Best of luck.
If this helped, please remember to vote! Thanks
Mar 15, 2011 | Video Game Consoles & Games
The game crashes when i start a match
Minimum system requirements
80 MB Hard Disk space
32 MB RAM (64 for Wýndows 2000)
DirectX 7.0a
Notes on Sound and Video Cards
a.) Problems with the Intel i740 Chipset
Users with an Intel i740 chipset may experience a dithered pattern overlaying the game in the front-end. Gameplay should remain fully playable.
b.) Problems with the ATI Rage Pro Chipset
For Windows 98 users:
The recommended drivers for the ATI Rage Pro chipset are the latest reference drivers found on We recommend Version 4.12.2632.
For Windows 2000 users:
Ensure that DirectX 8.0 is installed. It can be downloaded from Once installed, right-click on the FIFA 2002 shortcut on the desk top, select Properties, and add "3D=dx8z" to the end of the "Target" property.
c.) Problems with the S3 Savage4 Chipset
Users with an S3 Savage4 chipset may experience minor graphical issues in the front-end. Gameplay should remain fully playable.
d.) Problems with the KYRO Chipsets
In 640x480 the Pause menu overlay will appear to be missing part of the background. To fix this issue, set the resolution to 800x600 or higher. This will not affect game play in any way.
e.) Video Cards NOT supported by FIFA 2002
3Dfx Voodoo 1
3Dfx Voodoo Rush
Hercules Thriller 3D
Diamond Stealth II
Number Nine Revolution IV
Chromatic Mpact 2
S3 Virge
S3 Virge VX
S3 Virge DX/GX
S3 Trio 3D
Notes on Windows
FIFA 2002 supports Windows 95b, Windows 98, Windows 2000, Windows ME and Windows XP.
*NOTE - To install the game properly on Windows 2000/Windows XP, you will need administrator access to your machine. Consult your Windows 2000/Windows XP documentation for more information.
Known problems with Windows 2000/Windows XP:
During testing, some video cards experienced problems due to driver incompatibility issues. Check your 3D card manufacturer's web site to obtain updated Windows 2000 or Windows XP drivers.
Jul 06, 2010 | Electronic Arts FIFA Soccer 2002 for...
Prism 3d problem
What type of graphics card do you have?
The min for this game is:
32 MB DirectX® 8.1 certified video card with T&L - prism 3D errors are mainly based on your graphics card. Try installing a new driver for your graphics card as well as download and install the game patch from hunting unlimited website.
hope this helps, keep me posted
Aug 13, 2009 | Microsoft Windows XP Home Edition
My HIS Radeon x1650XT hangs after playing 3D Games.
change your graphics card or you may upgrade your card.
Jun 03, 2009 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Standard vga driver
it depends on what os you are installing if you are installing windows xp, all pre 2000 graphics card dont usualy need drivers in windows xp, if its not asking for drivers you maybe have to install them manualy
*DRIVERLINK* (winxp):
*DRIVERLINK* (win2k):
These are the last drivers made by ati for that graphics card
Dec 29, 2008 | ATI 3D Rage LT PRO, (8 MB) Graphic Card
Nvidia G-Force FX5200 256RAM
The following was taken from Based on the below description, I believe your problem would be solved by updating your video card drivers. The ones that ship with the card on cd are always very old. Here is a link to get the new drivers from NVIDIA. You did not say, so I will assume you have Windows XP, if so, here is the link for the most recent driver: If you do not have XP, then go to this link and find one for you OS If this works, I would appreciate a rating, I am new to fixya and would like to get a good rating. Thanks and Good Luck!! 14. I get a message saying: We are sorry, but the operating system failed to provide the window to render game graphics in. Bus Driver immediately crashes with a Prism3D error. There are several possible causes for this to happen. In most cases, the critical element of resolving the problem is upgrading video card drivers. (See #8 above)
  • Reportedly, some computer vendors ship new machines with the system preconfigured, but without proper drivers for the particular brand of 3D accelerator card installed, including OpenGL support. Make sure to always have proper up to date 3D card drivers installed.
  • Upgrades of certain Windows components (upgrade of DirectX, a Service Pack application) may require driver reinstallation afterwards.
  • You may have your desktop color depth (Color quality) in Windows set to 256 colors. Make sure you have Windows running in 16-bit or 32-bit color depth.
  • You may be using a very old computer with hardware capabilities below minimum specifications required to run Bus Driver.
Dec 14, 2008 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Flickering games red jumpy video
Do you have the latest version of direct x installed? Direct x sometimes can cause problems with games using 3d acceleration, as some versions of direct x are not fully compatible with the video card and/or the video card drivers.
Nov 29, 2006 | XFX GeForce FX 5200, Graphic Card
Microsoft Windows XP Professional Logo
203 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
