Question about Kenwood KDC-X817 CD Player
Need info ,repair
My kenwood kdc-x817 has a conection problem with the face I think? cause i can wiggle it and or apply presure at a certain angle and it will come on but only the demo not any funcions what can i do or is there maybe a problem with these decks
  • 111 Answers
Actually the problem is the ribbon cable,the one it connects the face to the main board.
You need to replace it.
You can get it at pacparts.com
Posted on Jan 29, 2008
I have a Kenwood kdc-x817 I get power but the only thin that move's is the face but it doesn't turn on...can somebody help me out pllzzz..thanx!!
If you have it wired up correctly you will still need the security code. Getting that from Kenwood if you don't have it is like trying to drink an ocean with a shot glass.
Feb 23, 2015 | Kenwood Car Audio & Video
I have a Kenwood KDC-X817 CD receiver and im trying to be able to use my ipod with it. It says on some on the online manuals that you can accept input from an auxiliary source When used with an optional...
I have the same problem with the KDC-x817 and i tried following these steps, but when I am in the menu and scrolling through the options, I don't see anything that says AUX off. Am i missing something??
Apr 25, 2011 | Kenwood KDC-X817 CD Player
Replace Flex-PCB in a Kenwood KDC-ps909
Don't remember but I think you need "Keys" a couple of funny shaped forks to press in the sides of the head unit...Frankly, if the PCB cable is bad (and you have one). Why not contact a local car audio dealer that sells Kenwood?
Good Luck
Jun 15, 2009 | Kenwood KDC-PS909
Problem with Kenwood x817 in my '95 audi A6
It sounds like the radio to me.
I work at a Kenwood authorized service center and have seen this problem many times. It is a common problem with this model and many other Kenwood models as well.
It has a ribbon cable that connects the display to the main board and they are almost always the cause of your problem.
The ribbon cable has a part number right on the cable in the skinny little area that laps over the connector that is on the main board of the radio.
the part number starts with either J84-xxx-xx or J86-xxx-xx
The "xxxx-xx" is the remainder of the part number. You can see what it is when you look at the cable. I just can't remember the entire part number right now without the service manual in front of me.
You can get that part at an authorized Kenwood repair center. If they don't have it in stock, they can order it for you. It cost around $20 to $30 depending on the shops mark-up of the part.
To replace that part you will also need to un-solder the metal connector that the face plate comes in contact with and solder it back on to the new cable.
You must also be careful taking apart the radio to repair it. Making sure that you don't force anything apart and causing more problems.
If you decide to do this yourself, let me know and I can give you some better instructions tomorrow when I have the service manual to look at.
It is reccomended that you let a proffesional do it for you.
The repair should not cost more than $100 for parts and labor. My shop would charge about $85.
I hope this helps you make an informed desicion on how to approach this problem.
I good rating is always appreciated for the help provided.
Thanks and good luck, just let me know if you need more help.
Jun 24, 2008 | Kenwood KDC-X817 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Jan 09, 2008 | Kenwood KDC-322 CD Player
Kenwood kdc-601fm
Hi the kenwood changers suffer from jamming up, and dry joints on the socket. try wiggleing the large socket/cable on the cd changer. otherwise you will need to take it for repair. if you would like to have it repaired, please see www.carradiospares.co.uk
Apr 26, 2007 | Kenwood KDC-C567FM CD Changer
Kenwood KDC-715s problem.
the kenwoods with the motorized face platesdevelop one problem with time. the flexable ribbon cable between the main unit & the face plate. as the face open & closes, over time wares out the cable. problem consists of face plate not opening/closing, display missing & and/or some or all buttons not working. note these can also be intermittent problems. typically the part number is located on the cable itself on the side where it pluggs into the main board. since you have a service manual, you should verify it in the manual. good luck.
Dec 03, 2006 | Kenwood KDC-715S
Kenwood KDC-X817 CD Player Logo
138 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
